  Missing Coolant/Vac Line
Missing Coolant/Vac Line by MasterBaker
Started on: 08-26-2023 01:05 PM
Replies: 8 (260 views)
Last post by: Vintage-Nut on 08-27-2023 04:21 AM
MasterBaker
Report this Post08-26-2023 01:05 PM Click Here to See the Profile for MasterBakerSend a Private Message to MasterBakerEdit/Delete MessageReply w/QuoteDirect Link to This Post
About my car 1986 Fiero GT 2.8 L with manual transmission. Can someone please help me figure out what is missing from this metal pipe. It’s approximately 1/2” dis. metal pipe that runs from middle of car toward driver side. It transitions from a metal pipe at the engine to rubber hose and runs forward. Appears to be a coolant line of some type. Take a look at photos to let me know all think. It’s relocated right below the wiring harness.
IMSA GT
Total ratings: 253
Report this Post08-26-2023 01:22 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's part of the GM recall. It is abandoned during that recall and does nothing.
Check the other end which goes to the air cleaner and if it is not disconnected there, put a cap on that open end so dirty air doesn't get sucked into your engine.
[This message has been edited by IMSA GT (edited 08-26-2023).]
MasterBaker
Report this Post08-26-2023 01:54 PM Click Here to See the Profile for MasterBakerSend a Private Message to MasterBakerEdit/Delete MessageReply w/QuoteDirect Link to This Post
What was its intended purpose? I don’t think it’s been disconnected from air filter. I will cap it as suggested. I’ll also look to remove the pipe all together. Again, thank you so much! Love the folks on this site.
Vintage-Nut
Report this Post08-26-2023 02:15 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
My dealer only installed a rubber cap on the right end of the metal pipe.
So, I removed the rubber hose from the air cleaner housing to the metal pipe; then installed rubber caps on the left of the metal pipe and the air cleaner housing.
Clearly, the air cleaner housing is the main focus; caps on the metal pipe are merely superficial than open ends.
Air Cleaner Housing to Engine Crankcase Vent which REMOVED and a NEW Engine Crankcase Vent tube (Part 10) to the NEW Air Intake (Part 13) at the Throttle Body.
See ILLUSTRATION I - AIR INLET (85-86) in the link below
No, another metal pipe is welded on the same pipe we're talking about which you cannot separate easily.
Remove your air cleaner cover and the housing can remove from the base to inspect if you have a hose or a cap on the port...
Edit
REASON FOR RECALL for '85-'88 V6
Campaign 88-C-24
https://www.boomtastic.com/...s/88C24%20Recall.pdf
Original Owner of a '88 GT and 'Under Refurbishment'
[This message has been edited by Vintage-Nut (edited 08-26-2023).]
Report this Post08-26-2023 06:28 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Instead of needing to rehash this over and over, there needs to be a "sticky" for us to refer to when this question gets asked here every few months.
The worse thing about that pipe, is that if it hasn't been capped at one end or the other, dirty air from the engine bay has been sucked into the filtered side of the air filter canister for years, probably for decades.
Vintage-Nut
Report this Post08-26-2023 09:29 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post08-26-2023 09:59 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Vintage-Nut:
CLICK FOR FULL SIZE
"WAS Air --->"?
What are you telling us?
[This message has been edited by Patrick (edited 08-26-2023).]
jelly2m8
Total ratings: 243
Report this Post08-27-2023 03:22 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Patrick:
"WAS Air --->"?
Exactly what you know, What was and what is new ( new being relative in the cars life cycle)
Vintage-Nut
Report this Post08-27-2023 04:21 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Instead of needing to rehash this over and over, there needs to be a "sticky" for us to refer to when this question gets asked....
DONE
'90 Fiero Recall: '85-'88 2.8L V6 (RPO L44) GM Campaign 88-C-24 w/ Part Illustrations
https://www.fiero.nl/forum/Forum2/HTML/147137.html
