I bought Rodney's ball joints and tie rod ends and I'm trying to make the job
easier by getting
Genuine GM Tools listed in the '88 factory manual.......
I've read many PFF threads on lower ball joints;
'Raydar' commented in 2013:
| quote | This was actually one of the more pain-in-the-azz things I've ever done with a Fiero. I bought the cheap ball joint press tool from Harbor Freight and still didn't have all that I needed. Ended up sawing one of the sleeves in half. |
Obviously, one huge issue when removing/installing lower ball joints is the proper adapters for the underside of the control arm.
SO, I purchased the correct Kent Moore Adapters as listed in the manual:
J-37161-1 and J-37161-3 to Remove
J-37161-2 and J-37161-4 to Install
Check Off 'proper adapters' and I also bought J-26407 to separate the ball joints to the knuckle.
My QuestionsThe Kent Moore J-9519-10 Clamp is 'unavailable' which holds these adapters to press the lower ball joints.
When looking photos of J-9519-10 Clamp and J-9519-23; they
seem to be the same or very similar.
I thought someone might know the difference between these clamps.
OR someone has the J-9519-23 clamp and will measure the I.D. of the welded ‘pipe’ on the clamp which holds the adapters? Perhaps J-9519-23 clamp will work.....
OR maybe I can weld this particular 'pipe' on a Kent Moore J-9519-8 (last link)
I wanted to hear from the forum before moving forward!
Photo of Kent Moore J-9519-10 Clamphttps://www.bing.com/images...s%3A%2F%2Fth.bing.co Photo of Kent Moore J-9519-23 Clamphttps://www.bing.com/images...A%2F%2Fi.ebayimg.comPhoto of Kent Moore J-9519-8https://www.bing.com/images...ttps%3a%2f%2fth.bing------------------
Original Owner of a '88 GT and under 'Production Refurbishment'
