  sticking caliper
sticking caliper by centervilledon
Started on: 09-29-2023 07:06 PM
Replies: 9 (439 views)
Last post by: reinhart on 10-22-2023 03:19 PM
centervilledon
Report this Post09-29-2023 07:06 PM Click Here to See the Profile for centervilledonSend a Private Message to centervilledonEdit/Delete MessageReply w/QuoteDirect Link to This Post
My right front wheel was very hot after a trip to town I suspect a sticking caliper. Any help with the will be appreciated
Report this Post09-29-2023 07:26 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check the caliper sliders and the brake hose.
If the sliders don't move, the outer pad will stay in contact with the rotor.
If the hose is pinched shut ( usually by rust forming in the brake hose clamp on the upper control are, the caliper will not return to the 'rest' position.
fierogt28
Report this Post09-29-2023 10:17 PM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
Old joe is correct on that. My 88GT had this issue after being in storage for 16 years. The front passenger caliper was sticking resulting in a brake hose failure. It’s the clamp on the UCA that, yes…can rust, causing a limited or very small brake, if any fluid passage. There is a lot of pressure when brakes are applied, so like Joe mentioned it’s restricted if the fluid can’t or doesn’t go back into the master cylinder reservoir. I might have had crap that even made the passage worse.
I replaced both front brake rubber stock hoses, and no sticking caliper / brakes after. You can feel the resistance like crazy because the brakes are applied on one side.
Naturally the rim gets really hot.
Do not drive around if your brakes are sticking.
You will glaze your disks and ruin your brake pads very quickly.
fierogt28
88 GT, Loaded, 5-speed.
[This message has been edited by fierogt28 (edited 09-29-2023).]
jelly2m8
Total ratings: 242
Report this Post09-30-2023 04:09 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
being a front wheel I would most definitely look at the flex hoses. the bracket that holds them to the control arm are famous for rusting internally and squeezing the flex hose shut, not allowing the pressure off.
[This message has been edited by jelly2m8 (edited 09-30-2023).]
ArthurPeale
Report this Post10-03-2023 09:25 AM Click Here to See the Profile for ArthurPealeSend a Private Message to ArthurPealeEdit/Delete MessageReply w/QuoteDirect Link to This Post
If those hoses are original, I'd replace them without a thought. $40-ish from Rock Auto is cheap insurance.
FieroPrblems
Report this Post10-03-2023 09:45 AM Click Here to See the Profile for FieroPrblemsSend a Private Message to FieroPrblemsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any one who can offer any help.. 86 fierro passenger rear caliper keeps blowing the rear plunger seal in the middle of the piston. I’ve replaced the caliper twice now. Any ideas?
ArthurPeale
Report this Post10-03-2023 04:50 PM Click Here to See the Profile for ArthurPealeSend a Private Message to ArthurPealeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Many rebuilt calipers can have issues. My only suggestion would be to bring it back, again.
Report this Post10-03-2023 05:49 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
When replacing brake hoses use SAE J1401 often sold as "pro grade" parts. see https://www.fiero.nl/forum/...HTML/129208.html#p27
Lube sliders & other brake parts right w/ Brake Grease or will fail & sooner not later.
https://web.archive.org/web...cast.net/~fierocave/ brake service.
If some fool use any other oil/grease then rubber o-rings on sliders have to be replace.
WT_ is the "plunger seal?" Do you mean Cut O-ring main seal goes on the piston? Cut O-ring seal on Park screw?
see https://web.archive.org/web...ierocave/brakes1.htm
Light Green is all "seals."
Main seal failing can be the "rebuilt" co have wrong size seal or other problems & fail when used. Likely replace under warranty but likely have same problem because often are same batch as 1st two...
JT6666
Report this Post10-03-2023 05:49 PM Click Here to See the Profile for JT6666Send a Private Message to JT6666Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had a rear caliper lock up at speed - big BANG !
saw a flash of flame in my side-view - guess it as brake fluid igniting.
Literature suggested the interior of the old factory brake hose deteriorated- caused blockage in the hose preventing brake fluid flow back.
reinhart
Report this Post10-22-2023 03:19 PM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
No warning leading up to it? Poor brake performance, noise, sticking, etc?
