  Stock Fiero shifter w/4t65e-HD swap
Stock Fiero shifter w/4t65e-HD swap by beaumontracer
Started on: 10-01-2023 03:36 PM
Replies: 9 (466 views)
Last post by: jelly2m8 on 10-08-2023 11:01 PM
beaumontracer
Report this Post10-01-2023 03:36 PM Click Here to See the Profile for beaumontracerSend a Private Message to beaumontracerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm swapping in a 2002 Regal 3800SC Automatic into my '88GT. Was curious how you all handle the shifter hookup. Being that the original was only 3 speed.
Can I get all 4 gears with the original Fiero shifter or do I need to change it for a 4 speed version?
richard in nc
Report this Post10-01-2023 04:28 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
you won't be able to shift to first gear.
Total ratings: 329
Report this Post10-01-2023 04:32 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe the Fiero auto shifter has an extra position for a forth speed selection but why do you need this in the first place? Even since I had my swap I just used the shifter to select P, R, N and D. Never saw a need for 1 and 2.
beaumontracer
Report this Post10-01-2023 06:46 PM Click Here to See the Profile for beaumontracerSend a Private Message to beaumontracerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I intend to drag race it as well as street drive. Just want to get all I can out of the performance increase.
jelly2m8
Total ratings: 243
Report this Post10-01-2023 06:52 PM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Incorrect.
The console shifter in mine with the 4T65E is un modified and I can pull it all the way down into 1st gear. Now the gear indicator does not align exactly to the correct gear past the D, but there is a positive feel and engagement for the 3 gears below that, well until I stuck down the 4 speed indicator strip from the donor car.
[This message has been edited by jelly2m8 (edited 10-01-2023).]
beaumontracer
Report this Post10-02-2023 05:51 PM Click Here to See the Profile for beaumontracerSend a Private Message to beaumontracerEdit/Delete MessageReply w/QuoteDirect Link to This Post
That would be great!
Total ratings: 329
Report this Post10-04-2023 07:18 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ideal shift pressures and WOT shift points can be programmed into the PCM. No need for any manual action.
Rickady88GT
Total ratings: 202
Report this Post10-07-2023 11:34 AM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I cut an extra "cog" or "tooth" or "detent" (what ever it is called) into the ratchet mechanism. It will stretch the shifter "boot" to it's extreme limits, but will reach.
Total ratings: 206
Report this Post10-08-2023 09:31 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
All of the auto Fiero shifters we have seen have detents for the four speed autos.
The transmissions also have detents built into the shift arm shaft (inside the transmission) that match up perfectly the the Fiero shifter detents, when using the proper length shift arm on the transmission.
No bell crank assembly needed.
jelly2m8
Total ratings: 243
Report this Post10-08-2023 11:01 PM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is a bit Ghetto, but I pulled the donor car's console apart and taped the Shift indicator strip down over the Fiero console
