  Transmission/Engine Mounts
Transmission/Engine Mounts by Jeffh110
Started on: 10-02-2023 05:32 AM
Replies: 5 (471 views)
Last post by: reinhart on 10-22-2023 03:04 PM
Jeffh110
Report this Post10-02-2023 05:32 AM Click Here to See the Profile for Jeffh110Send a Private Message to Jeffh110Edit/Delete MessageReply w/QuoteDirect Link to This Post
I won the fight to get all the auto transmission mounts and engine mount changed on my v6, at least I thought I did. They all lined up, I haven't bolted them all the way down yet. In victory I pop up from underneath... and... the dogbone mount on the engine is about 3/4 in to the right of where.it should be. If I jack the engine back up and it comes off the right engine mount about 3/4 inch it lines up. When I tighten down the rear transmission mount will it compress any? I did notice when it went in it was quite a bit taller than the original, but I assume that is just because the old was really worn. Any ideas?
angelasdad
Report this Post10-02-2023 10:58 AM Click Here to See the Profile for angelasdadSend a Private Message to angelasdadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The studs are offset on the mount, flip it around.
cvxjet
Report this Post10-02-2023 12:01 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
The engine mount studs are offset so spin the engine mount around. The Transmission mounts have two sets of holes in the subframe so you probably need to lift and shift those over.
[This message has been edited by cvxjet (edited 10-02-2023).]
Jeffh110
Report this Post10-02-2023 12:06 PM Click Here to See the Profile for Jeffh110Send a Private Message to Jeffh110Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the photo, that is helpful. I saw the 2 holes on the front mount, went back where it was but I will swap them around. Back I was doing mostly by feel!
Jeffh110
Report this Post10-08-2023 05:36 PM Click Here to See the Profile for Jeffh110Send a Private Message to Jeffh110Edit/Delete MessageReply w/QuoteDirect Link to This Post
Still stuck on this one. Engine mount is correct., transmission mounts can't shift due to engine mount. It looks like it comes down to height. New transmission mounts are 5/8" higher than removed so they bring that side up and in essence tip it toward the passenger side. If I bring thr passenger side off the engine mount by about 1/2" it lines up. What am I missing?
reinhart
Report this Post10-22-2023 03:04 PM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Think you answered your own questions. Buy different trany mounts. Wrong application or bad manufacturer.
