  Service Engine soon light
Service Engine soon light by Fatfarmer
Started on: 10-13-2023 10:59 AM
Replies: 5 (286 views)
Last post by: fierosound on 10-14-2023 09:59 AM
Fatfarmer
Report this Post10-13-2023 10:59 AM Click Here to See the Profile for FatfarmerSend a Private Message to FatfarmerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello
I have a 1987 SE 5-speed V6
On my way home today I noticed the service engine soon light come on
Just yesterday I had changed my engine oil at the distance of 5,000km
I dont have an owners manual and google doesn't seem to understand what I'm asking it so I was wondering if this light is a reminder to change your oil or if it was warning me of somthing about to fail like a check engine light
Only had my car for about 2 months and this is the second oil change it's gotten, 1 when I bought it and 1 yesterday.
If it is just reminding me to do an oil change how to I get it to turn off?
Thanks
fierosound
Total ratings: 286
Report this Post10-13-2023 11:11 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome aboard!
It is NOT an oil change reminder. Is it still on?
You should check the ALDL codes and get back to us.
http://calgaryfieros.com/OSGdocs/codes.html
https://www.fiero.nl/cgi-bin/main.cgi?ECMCodes
PDF Owner's and Service Manuals and more
https://fieroinfo.com/
[This message has been edited by fierosound (edited 10-13-2023).]
Fatfarmer
Report this Post10-13-2023 01:10 PM Click Here to See the Profile for FatfarmerSend a Private Message to FatfarmerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes it's still on. Stays on solid after starting the car. I will follow your instructions and get back to you with the code
Thanks
[This message has been edited by Fatfarmer (edited 10-13-2023).]
Fatfarmer
Report this Post10-13-2023 06:25 PM Click Here to See the Profile for FatfarmerSend a Private Message to FatfarmerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fatfarmer
Member since Aug 2023
Ok so I checked the code and it was a 21 gonna read a bit more about it and then try and fix
Thanks
Report this Post10-13-2023 07:35 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are several ways (all documented here) to check the continuity of the windings in the TPS. If the TPS itself checks out, then the harness and/or connector could be suspect.
fierosound
Total ratings: 286
Report this Post10-14-2023 09:59 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you downloaded the PDF of the 87 Service Manual, TPS diagnostics are on pages 6E3-A-32 to 35.
All you need is a digital voltmeter.
To clear codes from the ECM disconnect power to the computer.
You can pull TOP LEFT fuse, or disconnect/reconnect power connector near the battery.
