  What Year and Car for Best SC 3800 Engine?
What Year and Car for Best SC 3800 Engine? by rehoward
Started on: 10-15-2023 09:24 PM
Replies: 5 (1168 views)
Last post by: Darth Fiero on 10-25-2023 09:11 PM
rehoward
Report this Post10-15-2023 09:24 PM Click Here to See the Profile for rehowardSend a Private Message to rehowardEdit/Delete MessageReply w/QuoteDirect Link to This Post
What I am looking for in an engine swap is an SC 3800 motor as they are reported to have all the goodies, steel crank,
sintered steel rods, hypoeutectic pistons. Maybe other stuff I am not aware of. My plans are to drop an SC motor into
an '85 Fiero and run the SC until I can get a turbocharger put together. Then replace the SC with the turbo. I plan
to use the stock 4 speed manual trans that came with the car.
Is there a particular year or model of a factory supercharged 3800 engine I should be looking for? Might as well get the
best options while I am looking as I would like to keep the build costs down.
As another thought, are roller cams or roller rockers worth the investment or is there a better place to spend money on
this conversion?
Thanks for the help.
Randy
jelly2m8
Total ratings: 243
Report this Post10-16-2023 01:19 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Anything Series II and Series III which should be 1999 to 2007
Total ratings: 154
Report this Post10-16-2023 01:26 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Be aware that anything beyond 2005 will be drive by wire and doesn't use a throttle cable, so you will have to convert the throttle body to the earlier style.
Total ratings: 207
Report this Post10-16-2023 02:18 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
A better choice would be the Series III with the Northstar throttle body and an LQ4 MAF.
Slightly more money (although most of our swaps use that combo on the Series II and Series III) and you get to have a throttle cable.
Spoon
Total ratings: 61
Report this Post10-16-2023 08:21 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
One with the least mileage. Example, 2000 GTP 65k miles vs 2008 GTP 168k miles. If you're going to rebuild from the pan up then it may not matter too much except for the upgraded parts, SC, TB, etc.
Spoon
Darth Fiero
Total ratings: 361
Report this Post10-25-2023 09:11 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
this conversion?
Randy
No 3800 SC engine ever came with a steel crank - they all received cast iron cranks.
3800 Series 1 and 2 Supercharged engines had cast connecting rods. 3800 Series 3 engines (I think) had powdered metal connecting rods.
3800 Series 1 engines have very little performance aftermarket support. Their design is based on the old 3.8L V6 which has a 1" taller deck height (making the engine taller and wider) than the Series 2 and 3 3800's.
3800 Series 2 and 3 engines are essentially the same concerning hard parts except for the aforementioned connecting rods. The only reason the 3800 Series 3 SC engine made 20 more HP than the Series 2 as due to the improved Gen5 blower.
If you are planning on doing a turbo build, you can use any Series 2 or 3 Supercharged engine. The stock internals will endure 7-13 psi of boost reliably, perhaps higher boost levels if you are running E85 or race gas. The biggest issue with these engines is the stock pistons; more precisely the placement of the top compression ring land (too close to the top of the piston - which exposes it to more heat) and a very tight factory ring gap (which was done for emissions). You need to be careful with stock pistons and ring gap specs if you plan on running a lot of boost with a turbo.
3800 Series 2 SC was used from 1996-2005.
3800 Series 3 SC was used from 2004-07.
Best car to get a 3800 Series 2 or 3 engine from is a W-body (Regal, Grand Prix, Impala/Monte Carlo) because these engines received supercharger belt drive pulley brackets that work in a Fiero swap. C/H/G body 3800 SC engine supercharger belt drive pulley brackets will hit the Fiero firewall. Also, the W-body wiring harnesses are the easiest to modify to work in a Fiero. C/H/G body harnesses have an extra firewall bulkhead connector to deal with, which you don't need in a Fiero.
Check out my website for more info about my Turbo 3800 builds, and feel free to email or PM me if you have any questions (as I don't have time to visit this forum very often).
-Ryan
More is more. Less is not enough.
[This message has been edited by Darth Fiero (edited 10-25-2023).]
