  86 rear calipers
86 rear calipers by steve308
Started on: 10-23-2023 01:53 PM
Replies: 21 (468 views)
Last post by: steve308 on 11-28-2023 09:23 PM
steve308
Total ratings: 58
Report this Post10-23-2023 01:53 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes I've gone through the search feature. I'm looking for the difinitive answer on retracting the pistons. Is the following correct? (1) with e-brake cable disconnected the pistons are just pushed / c- clamped in and (2) with the e-brake cable left connected the piston must be rotated back in with the drivers side being counter clockwise.
Thanks in advance
Report this Post10-23-2023 01:58 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lever off & clamp the piston in.
https://web.archive.org/web...ierocave/brakes6.htm in rear brake section
steve308
Total ratings: 58
Report this Post10-23-2023 07:30 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you .
steve308
Total ratings: 58
Report this Post11-07-2023 10:13 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well the rear brake job went south in a hurry. Calipers are trash. Pistons are frozen, one all the way in, one all the way out. Tried to loosen the bleeder, yep snapped one off. I was successful in breaking loose one of the brake hoses at the caliper but I called it a day before trying the other side. Tracked down a new set of calipers and ordered new hoses just in case they are needed. Wife is not happy as the FIERO is up on jackstands dead center of the garage and her prized low milage CRV is out in the cold. Looks like it will be outside for a week or so.
steve308
Total ratings: 58
Report this Post11-14-2023 06:19 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Update and help still needed. New calipers arrived. Two day shipping only took 6 1/2 days but thats another fight. Attempted to install drivers side (rear). I am unable to get the piston back in enough for the pad to clear the rotor. I've measured all components and all parts are correct. Caliper is on the bench, bleeder is out but the piston just won't push back it bottoms out as shown in the pictures. Am I missing something?
Yes e-brake arm is off.
[This message has been edited by steve308 (edited 11-14-2023).]
PhatMax
Report this Post11-14-2023 06:49 PM Click Here to See the Profile for PhatMaxSend a Private Message to PhatMaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you tried to gently turn the piston in ? Who did the rebuild ?
steve308
Total ratings: 58
Report this Post11-14-2023 07:32 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Caliper is brand new. In the past and as per the Ogre's reminder I''ve always just pushed the piston in. Haven't tried a 'gentle twist' because I don't want to risk causing damage and make the calipers un-returnable. Thanks for the suggestion. I'll attack it again in the morning.
Additivewalnut
Report this Post11-14-2023 09:40 PM Click Here to See the Profile for AdditivewalnutSend a Private Message to AdditivewalnutEdit/Delete MessageReply w/QuoteDirect Link to This Post
if you can't get the piston to seat all the way and are afraid of breaking them, you could return them and look into getting 80s Grand Am brakes. Makes the pedal feel a bit better and they're WAY cheaper but you lose the ebrake. Doesn't matter if you have an auto or don't mind leaving it in gear.
IMSA GT
Total ratings: 250
Report this Post11-15-2023 12:15 AM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you able to just slip on the e brake cam and rotate it back and forth by hand to see if anything seats after a few cycles?
Frenchrafe
Report this Post11-15-2023 04:50 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
You tried what Ogre said ? Lever off and gentle push with clamp?
If nothing, then there's something blocked in the piston.
I've rebuilt these things many times, even though most people say it can't be done!
The inner part (with thread for the lever spindle) is not seating at the bottom of the piston. You need to disassemble and check; or you just need to send the whole think back under garantee, if you don't have the time/skills to open one up.
Personnaly, I would try turning the piston in with the lever in place. It might free up the stuck part on the threads? And get the piston to go fully in. You need to push and turn at the same time.
If it just stops at the same place as in your photo, then it's rebuild or send back time. 😉
"Turbo Slug" - '87 Fiero GT. 3800 turbo. - The fastest Fiero in France! @turboslugfiero
https://youtu.be/hUzOAeyWLfM
ArthurPeale
Report this Post11-15-2023 01:43 PM Click Here to See the Profile for ArthurPealeSend a Private Message to ArthurPealeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I also replied on your Facebook post, but it's worth repeating here, also.
Assuming all new parts - calipers, rotors, pads - it's possible that your piston is actually in all of the way, but that the pads are too thick.
I experienced this firsthand when I first started this hobby. I couldn't understand what I was doing wrong.
turns out...I wasn't. Some pads are simply just a tiny bit thicker than others. Not a problem on rotors with wear, but on a brand new rotor it will not work.
If you search my profile I've posted which pads I've used in the past. I can't remember off the top of my head.
Report this Post11-15-2023 07:02 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you can't get < 5mm 3/16" follow cave directions then something is block the piston.
Very Likely Turning the piston will not help or if does may hide whatever causing this & happen again w/o warning.
"Best" is return w/o taking apart or do other damage that voids the warranty or return policy.
"rebuilding" a new unit w/ this type problem is likely going to have more problems as the Piston is likely bad etc & you don't have new parts to fix.
Dangerous to start & if or more like When you wreck Illegal "upgrades"/"fixes," the I-co can Void the policy & have worse problems if other people are involved.
[This message has been edited by theogre (edited 11-15-2023).]
jelly2m8
Total ratings: 243
Report this Post11-16-2023 04:07 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
With the lever removed from the back side turn the treaded jackshaft so that it sinks into the back of the caliper some, then press the piston in, rinse and repeat until the piston bottoms. then reinstall the lever. Being a rebuild caliper it is most likely dry inside and that's a pretty hefty O-Ring on that jackshaft and will hold a lot of friction without some lubricant.
And No, your brake pads are not too thick.
[This message has been edited by jelly2m8 (edited 11-16-2023).]
steve308
Total ratings: 58
Report this Post11-16-2023 07:23 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
White flag waived. Two local repair shops couldn't get the piston to retrack enough to allow for rotor clearance. I went midieval on it just out of spite. Still beat my best efforts to destroy it. Up on rollers until I find a caliper that works.
Report this Post11-17-2023 01:30 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I take it you're not planning to return the calipers under warranty?
PhatMax
Report this Post11-17-2023 06:22 AM Click Here to See the Profile for PhatMaxSend a Private Message to PhatMaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well…. At that point, put an air hose on it and pop the piston out !
Frenchrafe
Report this Post11-18-2023 03:15 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Forcing the piston is not the answer!
Since you won't be returning the unit, now is the time to dissassemble carefully and start to understand how these things work😉
Use red rubber grease or industry/food grade silicone grease when reassembling.
You can do it!👌
steve308
Total ratings: 58
Report this Post11-18-2023 08:36 AM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
It's boxed up along with the unopened passenger side unit and ready to ship out.
richard in nc
Report this Post11-18-2023 01:31 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
imo a rebuilt caliper should already be all the way in and ready for new pads.
Report this Post11-18-2023 03:09 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Should try the P-side unit to if it retracts @ minimum to see if problem happened one time or not before you took other to shops that failed.
steve308
Total ratings: 58
Report this Post11-18-2023 07:14 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by theogre:
[QUOTE]Originally posted by steve308:
Should try the P-side unit to if it retracts @ minimum to see if problem happened one time or not before you took other to shops that failed.[/QUOTE]
I've ordered a replacement set. Hopefully better luck 2nd time around.
steve308
Total ratings: 58
Report this Post11-28-2023 09:23 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Update. The second caliper arrived and my local repair shop was able to compress the piston. I turned on the heat in the garage and hope to get the drivers side working tomorrow.
I'll pay the repair shop to hang the passanger side caliper and service the brake fluid.
