  is mat sensor same as air charge temp sensor ?
is mat sensor same as air charge temp sensor ? by traceymac
Started on: 11-04-2023 12:13 PM
Replies: 7 (211 views)
Last post by: Patrick on 11-14-2023 02:30 PM
traceymac
Report this Post11-04-2023 12:13 PM Click Here to See the Profile for traceymacSend a Private Message to traceymacEdit/Delete MessageReply w/QuoteDirect Link to This Post
i have replaced a parts cannons almost every sensor in this 87 GT , vac lines, egr and sensors,tps, distrib w/ icm trying to stop the high idle(1200), does idle down to a 1000 after warm up. new ecu, had to change mat sensor in air filter area due to mice eating wire. would a bad air charge temp sensor cause a high idle ? during warm up? have not changed cold start injector o rings yet, could this cause my higher idle? at wits end on this thing !
Report this Post11-04-2023 01:49 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Iffy sensor & wires to it Can problems but shouldn't cause high idle.
see https://web.archive.org/web...fierocave/ecmqrg.htm
buddycraigg
Total ratings: 478
Report this Post11-04-2023 05:14 PM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
can you stall the engine if you cover the IACM hole with your finger?
traceymac
Report this Post11-04-2023 05:53 PM Click Here to See the Profile for traceymacSend a Private Message to traceymacEdit/Delete MessageReply w/QuoteDirect Link to This Post
i replaced MAT, in air filter can, dont think i have replaced air temp module below thermostat housing. would this cause higher idle ? it idles arond 1200. when i put in gear it will try to idle down to under 1000 stumble and die sometimes not all the time ?.restart it and idles back up to 1200. then put in gear again and it stays 1200. its like its trying to come back to correct rpms but something is telling it to idle back higher ?
Spoon
Total ratings: 61
Report this Post11-13-2023 08:22 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
"mice"implies plural, more than (1). Are you sure (they) didn't have a smorgasbord on the entire harness in areas you can't easily see? This happened to my 2011 CTS and the number of codes (over 7) that showed up was breathtaking. $1800 worth of damage, but it still ran in limp-home mode.
Check your harness's closely.
Spoon
[This message has been edited by Spoon (edited 11-13-2023).]
Report this Post11-13-2023 08:57 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
You need to get a scanner on there to see what temperature readings from the MAT and CTS are being sent to the ECU. Incorrect readings can affect idle RPM, as will vacuum leaks.
fierosound
Total ratings: 286
Report this Post11-14-2023 11:15 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Before changing anything, check resistance with multimeter of MAT and CTS.
At ambient temperature, they should both read the same.
Report this Post11-14-2023 02:30 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I've checked mine, I've done it in the morning after the car has sat all night. The readings are usually very close to each other. If not, then there's a problem!
