  Hiro Coilovers - thoughts?
Hiro Coilovers - thoughts? by Lowerit
Started on: 11-13-2023 04:59 PM
Replies: 6 (609 views)
Last post by: fieroguru on 11-15-2023 07:53 PM
Lowerit
Report this Post11-13-2023 04:59 PM Click Here to See the Profile for LoweritSend a Private Message to LoweritEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone tried Hiro coilovers?
https://hiro-performance.com/84-88-pontiac-fiero/
I realize the pic is not for the fiero application, wanted some feedback on these for street driving -
Thanks.
Total ratings: 465
Report this Post11-13-2023 05:05 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
The fact that they use the same part number for all year Fieros makes me very suspicious about what exactly they are supplying for the front.
La fiera
Report this Post11-13-2023 05:09 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://hiro-performance.com/reviews/
This guy left a review and by the pictures he is from Ontario.
IMSA GT
Total ratings: 253
Report this Post11-14-2023 08:49 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
There was another review in there too.
[This message has been edited by IMSA GT (edited 11-14-2023).]
Spadesluck
Report this Post11-14-2023 10:02 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thats a pipe dream for the front of an 84-87 Fiero as it's not just a bolt-in solution. You will need significant work to have coilovers on the front for those years. The rears are very much doable.
Unless of course I am missing something?
Lowerit
Report this Post11-15-2023 12:12 PM Click Here to See the Profile for LoweritSend a Private Message to LoweritEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info guys. I have had ground control on the car, currently have a pair of speedway sleeves and springs on KYB's that have had the perch taken off with a lathe. Want something a little less home made. The front is just eibach springs, stock shocks. I'll probably take the plunge on these and document everything.
Total ratings: 259
Report this Post11-15-2023 07:53 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Before you drop a grand on this, ask them for some pictures of the actual parts they will sell you for a Fiero. Or even better, pictures of the parts actually installed on a Fiero.
There is no bolt in solution for the front. The front suspensions are completely different for the 84-87 and 88, so there is little change the same kit will work for both.
The rear with the same part #, even though the 84-87s have a different bolt pattern at the strut vs. the 88 is also suspicious. Add to that the option for a camber plate is another red flag.
They might be legit, but they would have to provide me with a lot more info before I dropped $1K with them.
