  Another day, another problem. Weird engine noise and oil leak
Another day, another problem. Weird engine noise and oil leak by Cliff Pennock
Started on: 11-23-2023 09:53 AM
Replies: 7 (385 views)
Last post by: Cliff Pennock on 11-27-2023 05:30 AM
Cliff Pennock
Administrator
Total ratings: 699
Report this Post11-23-2023 09:53 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
After recently replacing the exhaust, radiator, heater core, and addressing various other issues in the past few months, I had hoped to be done with car repairs for a while. I was wrong.
After these repairs, I had only driven the car short distances, max 25 miles per trip. During these trips, there was no overheating, the exhaust sounded fine, and the only leak I knew of was near the radiator, specifically leaking transmission fluid. I know the cause, and it's a straightforward fix that I plan to address once the weather clears up. So, at that point, I was content with the car's condition.
However, after embarking on a more substantial journey (100 miles to and 100 miles from), issues arose. The outward trip was problem-free, but when I started the car for the return journey a few hours later, I noticed an unusual engine noise which I had not heard on the way there. From inside the car, it sounds like a potential exhaust leak, almost like the distinct sound of one or more cylinders "popping." It is quite noticeable. Interestingly, the noise is barely audible from outside the car, making me doubt it is the exhaust. Listening in the engine bay, it sounds more like a ticking noise.
Upon checking the oil level, I discovered it was extremely low - so low that it didn't register on the dipstick at all. I promptly added about two quarts of oil, but this had no effect on the noise. The following day, I observed an oil puddle under the engine, precisely where the oil filter is located. I haven't replaced the oil filter in approximately 15 years, so it's much overdue. During my last inspection under the car (when replacing the exhaust), I noticed oil seeping from or around the oil filter, leading me to suspect that the oil filter itself is the source of the leak.
Despite these issues, I haven't noticed any changes in drivability. I drive my car conservatively—no hard acceleration, and I never exceed 75 mph. Now, the question is, how can I pinpoint the cause of the noise and/or the oil leak?
I have added recordings (made with my phone) of the engine. It's much more noticeable in real life, the recording hardly picks it up. I have two versions of each recording. The original and one with a high pass filter applied to get rid of the low engine rumble.
Original from within the car:
Engine rumble removed:
From the engine bay:
Report this Post11-23-2023 10:32 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could be valves or exhaust....
Take a piece of hose/tube pointed to exhaust manifold, in oil fill hole, etc & listen on other ends.
That Might tell where the sound come from w/o you getting hands burn.
Oil filter that old can fail in several ways & can leak too.
Worse the media can fail causing dirty oil to run thru it or force bypass in the block to open doing same. (Many GM engines have the filter bypass in the block not in the filter.)
Engine has ~ 4.5-5 quarts of oil & while being 2 quarts low, often doesn't kill the engine but won't help either because oil pickup can suck air when turning the car etc.
Total ratings: 460
Report this Post11-23-2023 11:30 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
In the engine bay recordings, I'm hearing something "random", in addition to a softer - but regular - ticking. The regular ticking sounds like a lifter tick to me. But then, so does an exhaust leak.
What does your oil pressure look like?
Please change your oil and filter.
Total ratings: 200
Report this Post11-23-2023 12:05 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
My thoughts are similar to Ogre's and Raydar on exhaust and lifters.
- An exhaust leak (from a cracked manifold) on the V6 can sound like a ticking noise.
- Failing lifters or a lifter that's not getting enough oil (or with bad lash) can also cause a ticking noise.
Both of these will produce a sound that is consistent with RPMs.
Now... the sound where you have the heading, "From the engine bay:"
That sounds like a similar issue to what my V6 Fiero currently has (as it sits in storage). You can watch that video here...
Like the audio from that sound recording, you have an intermittent sound that is inconsistent with engine RPM. That's the same as mine. To be completely honest, I never did figure out what caused this sound. It didn't affect engine performance... that I'm aware of, but I don't know. I have some thoughts that I wiped a cam-lobe, but I think the rattle would be consistent with engine speed. My guess is that it possibly has something to do with the torque converter (mine is an automatic), and likely either loose torque converter bolts, or possibly something rattling in the catalytic converter. Either of those would largely be inconsistent with the general rhythm of the engine.
lateFormula
Report this Post11-23-2023 12:37 PM Click Here to See the Profile for lateFormulaSend a Private Message to lateFormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
A ticking sound like that can be one of four things:
1) Ignition wire that is loose at either the distributor cap, or on a plug. The ticking would be the slightly muffled sound of the arc. This would be the easiest to diagnose.
2) Exhaust leak. Should be the second easiest to diagnose.
3) Valvetrain noise, probably the most difficult/time consuming to accurately diagnose and pinpoint.
4) Rod knock. Of the three options here, this would fall between exhaust leak and valvetrain for difficulty to diagnose. But it would still be a bit of a job.
[This message has been edited by lateFormula (edited 11-23-2023).]
Spoon
Total ratings: 61
Report this Post11-23-2023 08:21 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could be a deep engine knock in my opinion. To confirm, you could pull a plug wire off briefly (at the boot) to see if the knocking sound is reduced. Try this with each cylinder. Could be lifter noise, timing chain/gear, exhaust leak, etc. Be sure to use a tool with insulated handle to avoid getting shocked.
Spoon
[This message has been edited by Spoon (edited 11-23-2023).]
Report this Post11-23-2023 09:25 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Doing this could help finding a noise & cause Ignition problems because High Volts need a good path to ground or will find another path that can fry the coil, ICM, etc. in milliseconds.
You can use an ignition tester & then run the engine & repeat by shut off, move tester to another plug, run again.
Many types of tester available but I like one that is a mod'ed spark plug,,,
Cliff Pennock
Administrator
Total ratings: 699
Report this Post11-27-2023 05:30 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been really busy these past few days so haven't been able to do some more diagnosing. I have driven the car for a few short trips (again, around 20-30 miles) and don't notice any performance issues. But again, I drive my car very conservatively. But my real concern is if I should drive the car at all until I have found the problem...
