  Map lights not working anymore
Map lights not working anymore by Mark Schuessler
Started on: 11-29-2023 11:18 AM
Replies: 6 (323 views)
Last post by: theogre on 11-30-2023 10:29 PM
Mark Schuessler
Report this Post11-29-2023 11:18 AM Click Here to See the Profile for Mark SchuesslerSend a Private Message to Mark SchuesslerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Headliner replaced.. Dome light module changed to led bulbs courtesy lights work . Map lights will not. Even tried putting back oem bulbs. No go. # 8 fuse is fine, Any thoughts. Thanks
Total ratings: 200
Report this Post11-29-2023 02:52 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Mark... there's a connector that goes through the A-pillar down to the electrical block under the drivers side (just above the footwell). Have you checked to make sure it's getting power? It's possible that when you replaced the headliner, that this wire (that feeds the dome light) was not properly reconnected, or was in fact cut perhaps.
I don't have my Fiero in front of me, but I seem to recall that directly above the "dead pedal" on the drivers side (beyond the pull-down fuse panel), there is a white (and orange?) power distribution block that a lot of the options are plugged into, and this is where that light harness connects to.
da.slyboy
Report this Post11-29-2023 05:53 PM Click Here to See the Profile for da.slyboySend a Private Message to da.slyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The map lights are grounded to the roof panel on the inside (driverside) overhead console. You should be able to spot it with a connector on one of the mounting tabs. It's often the cause of the lights not working if the overhead console was removed then not properly seated (since it's grounded through only the small contact patch of the threads). I have in the past added a small metal washer on that screw for a little better contact patch of the screw head on the connector on the mount tab.
[This message has been edited by da.slyboy (edited 11-29-2023).]
buddycraigg
Total ratings: 478
Report this Post11-30-2023 06:57 PM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
I second the ground screw
Mark Schuessler
Report this Post11-30-2023 09:26 PM Click Here to See the Profile for Mark SchuesslerSend a Private Message to Mark SchuesslerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow, couple things. Never would have guessed but upon re-installing dome module. WaLa !!! 2 nd For several years I tried navigating he forum and admiittedly my lack of patience it was not working.NO MORE Thanks Fiero Nation
Mark Schuessler
Report this Post11-30-2023 10:03 PM Click Here to See the Profile for Mark SchuesslerSend a Private Message to Mark SchuesslerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mark Schuessler
Member since Aug 2017
Kudos to Da Slyboy .... Thanks Brother !!!
Report this Post11-30-2023 10:29 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dome & Map lights Lenses are made for 906 Tungsten bulbs.
The Dome lights are Flood Light & light the whole car & LED there won't matter to most people.
But turn on the P-side Map, 906 bulb output mainly light the passenger & while driver sees less outside @ night is not as bad as having the Dome On or having LED in the MAP section.
Note: Having Dome &/or Map lights On while driving can be a target for cops to stop you. Even ignoring that, the light pollution wrecks any night vision, worse when have no street lights etc.
If "hell bent" using LED, Do Not use "CANBUS" units! These have Low Ω Resistors Eat Power & Generate Heat.
