  Brake lights not working (Page 2)
Brake lights not working by Cliff Pennock
Started on: 12-05-2023 08:39 AM
Replies: 45 (618 views)
Last post by: theogre on 12-19-2023 01:50 AM
Cliff Pennock
Administrator
Total ratings: 699
Report this Post12-18-2023 02:10 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone any idea what could be causing the battery drain?
Cliff Pennock
Administrator
Total ratings: 699
Report this Post12-18-2023 07:46 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff Pennock
Member since Jan 99
Y' think this might be the problem? 😯
Total ratings: 200
Report this Post12-18-2023 09:17 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Oh no... I don't like that rust Cliff...
Cliff Pennock
Administrator
Total ratings: 699
Report this Post12-18-2023 01:36 PM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
The connector is completely separated from the chassis. Oddly, fiddling with that connector doesn't make a difference in the tail lights working or not.
Report this Post12-18-2023 04:00 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I brightened the image up a bit, I could more easily see the corrosion. Yikes.
Report this Post12-19-2023 01:50 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
That rust you see is likely just start of your rust problem. Need to pull inner fender to look @ upper frame.
Wires don't like edges of frame etc touching them. Pull C500 apart if needed to look @ bottom of wires better.
Even then rusted metal "swells" & may cut into the wires where wires go thru the body & frame farther down & very hard to see or fix.
C500 has 3 parts:
1. body section
2. engine section
3. "taillight" section that may have Cruise servo & other options.
3 is nested into 2 then both connect to 1.
