  Water dripping in trunk
Water dripping in trunk by NiotaFiero
Started on: 12-05-2023 12:49 PM
Replies: 8 (236 views)
Last post by: fierofool on 12-06-2023 04:47 PM
NiotaFiero
Report this Post12-05-2023 12:49 PM Click Here to See the Profile for NiotaFieroSend a Private Message to NiotaFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 87 gt has sweat forming on the rear trunk lid and drips into the carpet, what is causing this and what can I do to prevent this from happening?
Report this Post12-05-2023 02:32 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Leaking hardware for wing assemble & notchie deck lid rack does that.
cvxjet
Report this Post12-05-2023 03:12 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ogre is right, but....You might be getting rain water leaking in around the "d" panels on each end of trunk opening...the water then gets in carpet and while trunk is closed it condenses on trunk lid.
You should attempt to A) Check the sealing around those "D" panels (I sealed mine with RTV) and B) Dry out the trunk- open lid (When NOT raining/snowing) and possibly set a blow-dryer in there at low heat setting.
[This message has been edited by cvxjet (edited 12-05-2023).]
NiotaFiero
Report this Post12-05-2023 03:14 PM Click Here to See the Profile for NiotaFieroSend a Private Message to NiotaFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I’ve installed new wing hardware, but apparently not good enough.Thanks
NiotaFiero
Report this Post12-05-2023 03:21 PM Click Here to See the Profile for NiotaFieroSend a Private Message to NiotaFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
NiotaFiero
Member since Nov 2007
I have the carpet out and everything was dry.Since then we have had no rain and went out to run the car to keep the battery charged and that’s when I found the lid sweaty.
[This message has been edited by NiotaFiero (edited 12-05-2023).]
1985 Fiero GT
Report this Post12-05-2023 04:46 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had the same thing, I cannot guarantee that this is what caused it, but In my case it was because the carpet had gotten wet earlier, leaving some water underneath the carpet, because of the way the carpet is made, the underside can be soaked while the surface feels dry, and as the Fiero was driven and the trunk was heated up the water under the carpet formed into steam which then condensed on the deck lid. Which then gave the effect of dripping down into the carpet whereas in reality it was the opposite. Other things that could be is a leaking trunk seal, leaking spoiler gaskets, leaking gaskets around the trunk fan. In my case I removed the carpet thoroughly washed it and dried it, washed and dried the inside of the trunk, and my problem was fixed.
NiotaFiero
Report this Post12-06-2023 02:54 PM Click Here to See the Profile for NiotaFieroSend a Private Message to NiotaFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I installed a new trunk seal, new gaskets on the wing.The carpet is out and has been for a while , I haven’t checked the fan gasket,never thought of that, I’ll check that, thanks.
Report this Post12-06-2023 04:45 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any time I have the wing off, I use a little bit of butyl windshield setting tape underneath the retainer nuts inside the trunk to help seal the hole. A very thin washer-shaped piece on top of the decklid can help, too.
After replacing my gasket, I had leaks until I applied some sealer adhesive to the sides and extending down past the corner for a couple of inches along the back.
Report this Post12-06-2023 04:47 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Jan 2002
