  i have a 1987 base coupe.it doesn't have power windows.
i have a 1987 base coupe.it doesn't have power windows. by richard in nc
Started on: 12-23-2023 05:43 PM
Replies: 17 (335 views)
Last post by: 1985 Fiero GT on 06-21-2025 03:08 PM
richard in nc
Report this Post12-23-2023 05:43 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
since its IMPOSSIBLE to roll up the passinger side window while sitting in the drivers seat i bought two 1986?doors complete with power windows.my plan is to bolt them on and then swap the outer panel and the inner panel.
Report this Post12-23-2023 06:16 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by richard in nc:
since its IMPOSSIBLE to roll up the passinger side window while sitting in the drivers seat...
It's not "impossible"... it just requires a minor dislocation of the right shoulder.
Report this Post12-23-2023 07:30 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Be aware that the power mirror wiring changed slightly during the Fiero production run.
IIRC, it was between the 85 and 86 model year, but it's been about 20 years since I discovered it.....
I will look in my FSMs later and report back.
fierobear
Total ratings: 382
Report this Post12-23-2023 07:47 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you get a cross-car accessory harness?
richard in nc
Report this Post12-24-2023 12:40 AM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
i honesty tried to get the whole harness but it was run all over the car.im thinking i just need two wires to each door and a wire with a fuse to the battery.i always straight wire my cars so the power windows work without the switch being on.
1985 Fiero GT
Report this Post12-24-2023 07:38 AM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
You might have issues with the doors lining up, because of the way the mill and drill machine worked, all of the body panels lined up with each other in each individual car, but when you move a door complete with power skin to another car it likely doesn't like up perfectly, it would likely be easier to swap the guts out and put power windows in your original doors
Total ratings: 463
Report this Post12-24-2023 10:23 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by 1985 Fiero GT:
...it would likely be easier to swap the guts out and put power windows in your original doors
This is what I ended up doing. Freakin' doors are heavy.
richard in nc
Report this Post12-24-2023 12:14 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
i know.i picked them up in and out of my van.
Total ratings: 200
Report this Post12-24-2023 12:35 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just a few thoughts (my opinion only):
1 - For the doors themselves... more than likely, the power windows are *barely* functional as it is... so you're not really saving yourself much if ANY effort at all by swapping the doors. I say this because you're going to want to rebuild the motor tracks, rollers, and everything else. I'd say it would be different if we were still in the 90s, and you could still get lower mileage Fiero parts. But everything you're going to get today is either totally trashed, or has been sitting in the heat somewhere. Everything obviously uses interchangeable parts... but because of the way the jig was set up, the doors will have to be adjusted to fit properly... where as your old doors are already positioned properly for your car. So just my opinion... you definitely want to keep your old doors... take apart the inside, and disassemble, clean, rebuild, and install all the components from the other door into your new car. Trust me on this.
2 - If you can still go back to the car in the junkyard, definitely try to get the power window harness. It's not as complicated as it may seem (it's WAY less complicated than power door locks), but you'll be saving yourself a lot of effort. You should get the switches, harness, center console switch bracket, etc. The entire harness basically runs along the center console, and then it's taped into the larger harness (though not connected to it) as it goes through the dash on either side to the doors. It connects into an "accessory power distribution block" which is located under the drivers side... basically... up against the firewall behind the fuse panel. It's really convenient because it's a large white block (if I remember correctly), that different accessories basically just plug into. Super convenient.
... if you absolutely, cannot get the old harness, then I recommend using the service manual to reconstruct the harness. You don't want power going through the switch... you only want to use that to control a relay.
fierobear
Total ratings: 382
Report this Post12-24-2023 02:28 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
I use a floor jack under the door to hold it up. Find a balance point. Pump or release to adjust. Might need an extra pair of hands.
fierobear
Total ratings: 382
Report this Post12-24-2023 02:29 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierobear
Member since Aug 2000
The cross-car harness should be a lot more complex than two wires, plus the connectors and controls/switches are nice to have.
As for the replacement doors being gummed up, try to clean old grease out or at lease grease the window tracks as well as you can. Unless the motors are shot, greasing the tracks alone should speed up the window up and down speed quite a bit. I used Marine Grease. Smells for a while, but worked very well. Windows went from very slow to at or near normal speed.
[This message has been edited by fierobear (edited 12-24-2023).]
richard in nc
Report this Post12-24-2023 03:24 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
i got the harness from the switches to behind the radio and from the ends of the dash to the doors.i was an hour from my house and had somewhere to be.i also need to install my fiero store window weatherstripping.
Total ratings: 200
Report this Post12-26-2023 11:57 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
You should still be good to go... however, as I mentioned above, I recommend you download the service manual (for free) and reconstruct the original harness, and find the pig-tail end for the power source, and plug it into the original port on the power block. This will ensure that the fuse dedicated to power windows and the other accessories is properly used.
EDIT: I've done this before too a few times for most of the accessories. I hate to say it... because it's both sad and sucks at the same time, but ~15 years ago, my local junkyard had three new Fieros in it every single week (they'd be crushed and replaced by the following Thursday). It seemed like they were always loaded with every option. Many 88s, some loaded 85 GTs with the fleece seats, several Formulas, and multiple T-Top Fieros. But in every case, I'd grab the harnesses and such (I had both the time, and parts were absurdly cheap). I'd probably upgraded at least 3-4 Fieros that I'd bought and sold over the years with these parts. Kinda makes you sad that they're not so plentiful anymore, but also makes you realize how many were probably crushed. This was JUST in South Florida... one junkyard, and they were all rust free Fieros. I can assume that during that time, you had the same thing going on everywhere else at every other junkyard.
[This message has been edited by 82-T/A [At Work] (edited 12-26-2023).]
richard in nc
Report this Post12-26-2023 02:10 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
i threw 12 volts to one of the doors[windows] and it barely moves.so i will be taking it apart.
Report this Post12-26-2023 03:55 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Outer "skin" is located by One Screw near the outer handle under the trim. All others just holds it on the door.
Do Not Adjust big black plastic "screw" on the door frame that the small screw goes into.
If you remove a door from the car for any reason... The bolts from hinge to door allows 3 ways to adjust. Vertical, Horizontal & Twist. Twist is where upper & lower hinges are adjusted opposite of each other.
You must have Door adjusted close to right Before you try closing the window or things will break, seal can tear, etc.
See https://web.archive.org/web...cast.net/~fierocave/ door & window pages.
Note: Door page was written for damage doors... Install Rear screw in the OE hole first then most to all others "finger tight" to check skin fit to other panels.
[This message has been edited by theogre (edited 12-26-2023).]
sdgdf
Report this Post12-30-2023 09:42 PM Click Here to See the Profile for sdgdfSend a Private Message to sdgdfEdit/Delete MessageReply w/QuoteDirect Link to This Post
Never realized they were that heavy. I recently got a door from pull a part and that Fiero was at the very back corner of the lot! Hauled it back in a wheelbarrow. Ugh.
richard in nc
Report this Post06-21-2025 12:28 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
are you saying theres relays on the power windows somewhere?the glass on the parts door is scratched badly on the inside.the felt wore away.so im trying to convert my car door.i went ahead and ordered new felt guides and will have to wait til they get here.i test fitted the power window mechanism in the door and it should bolt in.
[This message has been edited by richard in nc (edited 06-21-2025).]
1985 Fiero GT
Report this Post06-21-2025 03:08 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
No the windows are directly driven by the switches, the door locks are relay driven.
