  Help! 3.4DOHC Firing Order
Help! 3.4DOHC Firing Order by fliphone
Started on: 12-24-2023 08:51 PM
Replies: 2 (135 views)
Last post by: olejoedad on 12-25-2023 01:01 PM
fliphone
Report this Post12-24-2023 08:51 PM Click Here to See the Profile for fliphoneSend a Private Message to fliphoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey there everybody! Merry Christmas Eve! I'm so close to starting my LQ1 for the first time but cannot find consistent information on the firing order/coil packs. Part of the reason is my coil packs are a hodgepodge from multiple cars (bought an unfinished swap) and I can't trust how they are labeled. The picture attached shows the current diagram I'm working off of, can anyone confirm if what I'm seeing here is correct? I've also attached a picture of my coil pack to show where some of my confusion is coming from.
Any help with this would be greatly appreciated, thanks guys!
marc-alan
Report this Post12-25-2023 11:22 AM Click Here to See the Profile for marc-alanSend a Private Message to marc-alanEdit/Delete MessageReply w/QuoteDirect Link to This Post
For a factory wasted spark setup, the diagram is correct.
For my lq1 build I had to rotate the firing order by 1 because of the standalone ecu I was using.
Total ratings: 206
Report this Post12-25-2023 01:01 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does the coil pack mounting plate have the firing order cast into it?
All of the other's I have seen have small numbers cast on them.
