sleek fiero
Big trunk shops & related may have something. Careful how to ask because Many don't want to deal w/ general public.
| quote | Originally posted by olejoedad: The line pulls a vacuum, but unless there is an air leak in the booster, no air moves. |
That line will flow air Every time you push the pedal activating the booster.
Worse w/ any problem causing Low Pedal forcing more booster moving.
Some Boosters have muffler/filter @ pedal rod for same reason. But old boosters wear out that "feature" letting small crap thru the booster.
Boost line or Booster itself can fail & thanks to Fiero Mild Steel line that rust & collect other crap can dump that in the engine.
Even People put crap in the Fiero Frunk then knock off the line or break the check valve w/ engine running does same thing.
Many would think open booster line = vac leak so big will instant kills the engine but often won't do that or soon enough so engine doesn't suck crap.
Often doesn't break completely open plenty of air flow allowing rust & crap sitting for decades to move.
