  16” wheel help for 84 SE
16” wheel help for 84 SE by Sayakachibi
Started on: 01-07-2024 06:59 PM
Replies: 2 (169 views)
Last post by: Raydar on 01-15-2024 12:32 PM
Sayakachibi
Report this Post01-07-2024 06:59 PM Click Here to See the Profile for SayakachibiSend a Private Message to SayakachibiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I need help finding tire sizes and the offset. I do have lowering Eibach springs on it. I’m thinking of doing 16x7 wheels. If you have photos please post them! Especially if you have non GT’s
cvxjet
Report this Post01-08-2024 12:39 AM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have 16 x 7 VOXX Monza wheels- the offset is 38 mm which improves steering effort while cutting back the Kick-back. Sadly, Voxx stopped making them back a few years ago- but the size is perfect. I am running 205/55-16 up front and 225/55-16 in back (these were sizes used by many popular cars back in the 90s- so lots of options in these sizes). The tires are General G-Max all-season tires which rate very favorably in Tire-Rack testing and are cheaper than most. Make sure you pick wheels that are light- I eliminated 3 lbs from each rear wheel and 6 lbs from each front (205 vs 215 previous size)- and the car went from driving like a truck to driving (basically) like a new car...
(Additional note; Looking for wheels- you can look for Subaru WRX 2000-2006.... although the offset is more- it will help with steering effort/kick-back in front...in back you can use longer studs and aluminum spacers to move the wheel-tire out a bit)
[This message has been edited by cvxjet (edited 01-08-2024).]
Total ratings: 463
Report this Post01-15-2024 12:32 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
A quick note about Subaru wheels... From the factory, they have a smaller centerbore hole. Will need to be bored out to 57mm to fit the Fiero.
LOTS of older VW wheels have the correct bolt pattern (5x100), centerbore, and offset to fit a Fiero.
PT Cruiser and Neon wheels should also fit. (I've seen the 15" Fiero lace wheels on a Neon. Looked really good. )
Edit - I also posted in your Farcebook thread, regarding sourcing a decklid and spoiler.
Welcome to our obsession!
[This message has been edited by Raydar (edited 01-15-2024).]
