  500 Cubic Inch Cadillac Fiero
500 Cubic Inch Cadillac Fiero by tgcarls
Started on: 01-15-2024 04:27 PM
Replies: 14 (406 views)
Last post by: Additivewalnut on 01-19-2024 04:13 PM
tgcarls
Report this Post01-15-2024 04:27 PM Click Here to See the Profile for tgcarlsSend a Private Message to tgcarlsEdit/Delete MessageReply w/QuoteDirect Link to This Post
As a new member, I thought I would share this winters project. It is a 84 Fiero Pace car with 500 cubes of Cadillac. A long time friend of mine built this car in the early 2000's, he sadly passed away a couple of years ago and I bought this from his wife. The car had been sitting for quite some time and needs some tlc to get it back on the road. Thought you might enjoy.
Report this Post01-15-2024 06:11 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry about your friend... but I had to laugh at this:
Do you mind sharing his Pennock's screen name?
Looks like he's using a Th-425 w/ Caddy 500 from an Eldorado. I pulled one of those motors (an original 27k low mileage one from a show car in the junkyard that a tree had fallen on). Those engines were sick. They didn't have much RPM... but they had almost ~600 ft-lbs of torque (grossly under-rated), and something like 11.25:1 compression. I don't know what year, but it's possible the Th-425 might even be a "Switch Pitch," which is pretty awesome... (look for 2 pins coming off the torque lockup pin).
If it were my car, I'd probably get rid of the big air cleaner stack, and I'd drop a modern fuel injection system on it and see if I could manage to get a semi-normal decklid back onto it. Any one of those modern fuel injection systems are built just for big engines like this.
Have you been able to drive it? I'd love to know what kind of performance you get from it.
IMSA GT
Total ratings: 253
Report this Post01-15-2024 06:39 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
This wouldn't happen to be Matt Kneen's car?
tgcarls
Report this Post01-15-2024 07:01 PM Click Here to See the Profile for tgcarlsSend a Private Message to tgcarlsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes it was Matts car. I met Matt when I was 13, he and built many projects over our 39 year friendship. He could engineer anything. Big loss to family and friends.
tgcarls
Report this Post01-15-2024 07:09 PM Click Here to See the Profile for tgcarlsSend a Private Message to tgcarlsEdit/Delete MessageReply w/QuoteDirect Link to This Post
tgcarls
Member since Jan 2024
I spoke to company in New Mexico that only builds Cadillac engines, he said I only gain about 10-15hp with the performer intake and lose the same or more at the bottom end. So I am going to remove it and just run the factory low intake. If I do that I can get the decklid back on. I have to replace the engine as this one got water in it while sitting, the engine I have is 78k miles low compression version, but with cam and a few other tricks from the Caddii Company, it will be around 380hp and 600 ft pounds of tq. My friend use to street race it in Mpls and seldom lost a race. There are pics of it pulling the front wheel off the ground. Should be fun!
Report this Post01-15-2024 07:34 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
I highly recommend (if you can) to rebuild that Cadillac 500 engine. Are you saying this is the low-compression version, or are you saying the replacement version is?
Do you know for certain that the engine is bad?
Totally agree about using the Eldorado intake... the extra 15hp is not worth everything sticking out the top. Definitely look into a modern fuel injection system... they have a new HEI computer controlled distributor for those motors. You can get better fuel economy, and significantly more usable performance with modern fuel injection... plus, it'll sit lower with a low-rise TBI unit... or if you can get a custom intake plenum... you can go MPFI.
Total ratings: 259
Report this Post01-15-2024 08:50 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post01-16-2024 07:57 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
https://www.fiero.nl/forum/...090219-1-062869.html
Weird how back in the day, there were so many people getting banned in the Tech section. There seems to be this "one guy" consistent in all of those threads, Shawn. I know nothing about him, but I keep seeing his name pop up in every thread where someone is banned, and there's always a fight it seems.
tgcarls
Report this Post01-16-2024 08:49 AM Click Here to See the Profile for tgcarlsSend a Private Message to tgcarlsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for that
Spadesluck
Report this Post01-17-2024 05:26 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
First thing I would address is the rust. No good having a big motor only to have it fall out because of rust.
IMSA GT
Total ratings: 253
Report this Post01-17-2024 06:41 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Shawn loved this place
Total ratings: 461
Report this Post01-18-2024 01:50 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think y'all are both thinking about a different Shawn. Errr... Shaun.
Additivewalnut
Report this Post01-18-2024 11:24 PM Click Here to See the Profile for AdditivewalnutSend a Private Message to AdditivewalnutEdit/Delete MessageReply w/QuoteDirect Link to This Post
I could probably dig around and find out myself but I gotta ask, how does it get power to the wheels in that orientation? Is the differential under the oil pan or something? How does the transmission even fit? I see these in the fiero car show videos that FieroAustin posts and I'm always confused on how it even works!
Report this Post01-19-2024 07:52 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
It uses a special kind of transmission that's no longer made, it's called the Turbo-Hydromatic 425... .Th425 for short. They also had a TH325 which was a lesser version. They were the front wheel drive versions of the Th-400 and Th-350 respectively ....
Th400 = Th425
Th350 = Th325
The Th425 was found in cars like the Cadillac Eldorado and the Oldsmobile Toronado.
The Th325 was found in the same cars, but in the later years... 1978+
The 425 essentially became the 325, though they are slightly different transmissions. When Cadillac and Oldsmobile transitioned from huge big block motors to small block V8s (metaphorically speaking) from the mid 70s to the late 70s, they switched to the lesser version.
https://en.wikipedia.org/wiki/Turbo-Hydramatic_425
There was also something called a "Switch Pitch" version of these, which is super rare, and really, really cool... it basically allowed you to change the stall speed of the torque converter on-command. It allowed you to alternate between a stall speed of about ~1,000 rpms. Lower stall speed for normal driving, and higher stall speed for performance driving. it would essentially be a little switch that mounted under the gas pedal... so when you'd floor it, the gas pedal would push down on the switch and give you a higher stall speed, allowing the motor to rev up before the torque converted engaged... giving you a nice launch.
https://www.jalopyjournal.c...switch-pitch.674586/
EDIT: I don't know who's car this is... but they used a Th-425 to build a replica Lamborghini Diablo from a Fiero:
https://www.flickr.com/phot...7076/in/photostream/
Click the right button to go to the next image. I start actually thinking it might be a real Diablo, until the shots where I see the good ole-fashioned GM steering column.
[This message has been edited by 82-T/A [At Work] (edited 01-19-2024).]
Additivewalnut
Report this Post01-19-2024 04:13 PM Click Here to See the Profile for AdditivewalnutSend a Private Message to AdditivewalnutEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's so cool!! I love learning about the oddball stuff that came out of the 60s and 70s. That whole transmission is super neat too, I'm amazed they got all that into such a small package given the era.
That's also really cool but you have to wonder if by the time he was done with it, if it would've been cheaper and easier to just get an actual Diablo
