  Stock Subwoofer Amplifier Mounting
Stock Subwoofer Amplifier Mounting by Indy-453
Started on: 01-21-2024 02:39 PM
Replies: 5 (322 views)
Last post by: 82-T/A [At Work] on 01-21-2024 03:31 PM
Indy-453
Report this Post01-21-2024 02:39 PM Click Here to See the Profile for Indy-453Send a Private Message to Indy-453Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am going through the process of installing a stock subwoofer system I got on ebay into my Indy. For the amplifier, does it just sit behind the carpet and plastic on the passenger side of the tunnel, or is there some kind of mounting bracket that I am missing?
Total ratings: 200
Report this Post01-21-2024 02:52 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know how helpful this will be, but I installed the subwoofer (with the replacement Rodney Dickman speaker) in my Fiero over a decade ago, and took a bunch of pictures at the time. You can see what it looks like with the dash removed (note: you do not need to remove the dash to install it):
https://www.pontiacperforma...l#SPEAKERS-SUBWOOFER
Bottom line, it doesn't affect the carpet. The carpet stays where it is, and it mounts under the dashboard just above the passenger side foot-well (where the "dead pedal" would be). There are a few components... you have the subwoofer box with tube. There's also the bracket / factory amplifier that sits on the passenger side of the center tunnel (under the carpet), and the PERFORMANCE SOUND boost slider that mounts in the overhead console. Finally... of course there is also the wiring harness...
IMSA GT
Total ratings: 253
Report this Post01-21-2024 03:13 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is from another thread. The area that is circled in red is where the stock amp mounts.
[This message has been edited by IMSA GT (edited 01-21-2024).]
Indy-453
Report this Post01-21-2024 03:13 PM Click Here to See the Profile for Indy-453Send a Private Message to Indy-453Edit/Delete MessageReply w/QuoteDirect Link to This Post
I got the sub box in no problems, other then putting in the tang band woofer which was an adventure on its own. But for the amplifier (circled in green), does it just sit there, or would it normally be fastened to something?
IMSA GT
Total ratings: 253
Report this Post01-21-2024 03:18 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes it mounts there but with screws.
Total ratings: 200
Report this Post01-21-2024 03:31 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
LOL, sorry... I missed the part where you said "amplifier."
Yeah, the FACTORY amplifier should slide into a bracket that's part of the panel that goes UNDERNEATH the carpet. I had an 87, and the bracket already had the slot for it... it just slipped in and fixed with a screw. What year car do you have? I can't remember (to be honest), if every Fiero 86+ came with the same bracket or not... but I know the 84s did not, and possibly the 85s as well. You may need to get the bracket as well, but honestly... I just remember it sitting in there.
[This message has been edited by 82-T/A [At Work] (edited 01-21-2024).]
