Hey John,
I hope you know now that this 'vacuum tube mystery' is one of the original plastic vacuum lines that has been cut/shorten and 'repaired' using rubber vacuum hose. The key is which vacuum line?
I'm
guessing it's the smaller throttle body vacuum line and the rubber vacuum hose in your hand shown is going to the bottom port of the EGR Solenoid.
BTW - The original plastic vacuum lines under the plenum are flexible when disassembling or assembling parts; however, they can get brittle and break from age and/or heat.
Both Rodney Dickman and The Fiero Store offers V6 Vacuum Line Replacements:
Rodney's V6 Stainless Steel Vacuum Lines
https://rodneydickman.com/p...o.php?products_id=86TFS Black Powder Coat Finish V6 Vacuum Line Set
https://www.fierostore.com/.../Detail.aspx?s=52389However, these rigid steel lines have no "give" and are much harder to disassembly parts or aligning them when installing, especially the bigger tubes.
I made a 'Hybrid':
I cut the original plastic 'ends' with their rubber boots; then
Reduce/cut Rodney's V6 Stainless Steel Vacuum Lines, and
Connected and sealed the plastic and steel tubes with rubber vacuum hose which I.D. was slightly smaller than the plastic/steel O.D.
This Hybrid has enough flexibility so I can replace my PVC valve easily....
So, you can 'repair' your original plastic vacuum lines with rubber vacuum hose (spaghetti method) using the diagram;
or replace them with these vacuum line sets.....
You're 'good to go'?
[This message has been edited by Vintage-Nut (edited 02-18-2024).]
