  Valve cover leak
Valve cover leak by Garrett5982
Started on: 03-25-2024 06:47 AM
Replies: 6 (323 views)
Last post by: Vintage-Nut on 03-26-2024 11:22 AM
Garrett5982
Report this Post03-25-2024 06:47 AM Click Here to See the Profile for Garrett5982Send a Private Message to Garrett5982Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys, I noticed that my '85 GT has a small bit of oil seepage on the valve cover. i was mostly wondering if it's something i should be immediately concerned about or if it's fine to prioritize other repairs first.
Report this Post03-25-2024 08:03 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
A leaking valve cover isn't an end of the world kind of thing by any means. The only problem though is that it gets oil everywhere, and makes any future work you're going to be doing extremely messy. It's an inexpensive gasket, so I'd change it sooner than later if it were me. But if your engine has never been cleaned, and it likely already has caked on oil, then I'd probably not be too concerned about it (right now).
Total ratings: 465
Report this Post03-25-2024 04:48 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
When you replace the valve cover gaskets, don't use the cork ones... use the rubberized ones. And as an aside, the middle intake plenum need not be removed.
Garrett5982
Report this Post03-25-2024 08:36 PM Click Here to See the Profile for Garrett5982Send a Private Message to Garrett5982Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sweet thanks for the info. is there anything specific i should look at while i have it apart? i've never opened this engine up before
Total ratings: 465
Report this Post03-26-2024 01:20 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
is there anything specific i should look at while i have it apart? i've never opened this engine up before.
Well, the engine really isn't "opened up" all that much during this process. It is a convenient time though to make your valve covers and upper intake all purdy while they're off the engine, either by cleaning them thoroughly and/or re-painting them (depending on how bad they are). Just be careful with the vacuum lines as they can very easily be broken.
[This message has been edited by Patrick (edited 03-26-2024).]
Report this Post03-26-2024 10:18 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Small leak there can make smoke to cause a fire when get on exhaust parts. Not something to ignore for long term.
Gaskets... Check if felpro has Permadry etc for the engine.
May, often does, cost more but works better. Example: Felpro L4 cover casket w/ metal frame silicon gasket includes new longer bolts & load spreaders to seal "weal" steel covers & cost a lot more but way worth the $ to never leak again.
Follow directions, Many gaskets of all types Install Dry or can use Permatex High Tac to hold in place. Problem is many add RTV etc to them then blame the gasket for problems.
RTV is only seal sections w/ seems like many oil pan sets. Or replace gaskets entirely following several rules.
Then Do Not over torque or will smash them & cause leaks right then or sooner not latter & why many "hate" the cork gaskets. Cork types are way easier for that because most people crush them @ install.
Clean the parts & parts & holes to get oil off/out then "torque by hand" using nut driver or ratchet held @ head. Hole(s) likely will still have enough oil in them making torque table useless. Even still, Clean parts + "springy" gasket will keep the bolts tight on most engines.
If some bolts still back out, I use plumbing Teflon tape as thread locker w/o problems using Loctite on small bolts. I use this on AT Pan bolts because steel bolts in aluminum that get loose or worse "rust welded" because some holes on some units go thru the case & get salt etc on back side.
(Permatex does make loctite for small screws but won't stop "welded" problems as just said.)
Vintage-Nut
Report this Post03-26-2024 11:22 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Patrick:
Yes, the original flexible plastic vacuum lines under the plenum can get 'brittle' from age and/or heat.
This is the perfect time to check them and both Rodney Dickman and The Fiero Store offers V6 Vacuum Line Replacements:
Rodney's V6 Stainless Steel Vacuum Lines
https://rodneydickman.com/p...o.php?products_id=86
TFS Black Powder Coat Finish V6 Vacuum Line Set
https://www.fierostore.com/.../Detail.aspx?s=52389
However, these rigid steel lines have no "give" and are much harder when disassembling or aligning them when installing, especially the bigger tubes.
I made a 'Hybrid' set:
I cut the original plastic 'ends' with their rubber boots; then
Reduce/cut Rodney's V6 Stainless Steel Vacuum Lines, and
Connected and sealed the plastic and steel tubes with rubber vacuum hose which I.D. was slightly smaller than the plastic/steel O.D.
My Hybrid set has enough flexibility so I can replace my PVC valve easily....
