  Vss part number
Vss part number by Jimih941
Started on: 03-30-2024 08:57 PM
Replies: 7 (155 views)
Last post by: olejoedad on 04-29-2024 09:08 PM
Jimih941
Report this Post03-30-2024 08:57 PM Click Here to See the Profile for Jimih941Send a Private Message to Jimih941Edit/Delete MessageReply w/QuoteDirect Link to This Post
Looking for the part the number for 1985 gt 4 speed vehicle speed sensor.
jelly2m8
Total ratings: 243
Report this Post03-31-2024 04:01 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
no idea without some digging, but what tells you you need a new VSS ( Vehicle Speed sensor ) ?
Have you carefully removed it and seen if the drive gear is still attached?
[This message has been edited by jelly2m8 (edited 03-31-2024).]
Total ratings: 206
Report this Post03-31-2024 07:39 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
They used to be unobtainium, I don't know it anyone has started to make them.
All Of the manual Fiero VSS units are the same, but there are different color gears for the different wheel/tire combos.
Jimih941
Report this Post03-31-2024 08:11 AM Click Here to See the Profile for Jimih941Send a Private Message to Jimih941Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks. I’ll take a look at the current one for the color and if the gears are still intact.
Total ratings: 206
Report this Post03-31-2024 10:48 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can use a DVM and spin the shaft to see if the unit works.
Vintage-Nut
Report this Post03-31-2024 11:40 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
SENSOR; Vehicle Speed Sensor
GM Part Interchangeable Numbers (discontinued)
25007336
25007316
BTW - The PFF 'Search' function is your best friend.......Search 'Vehicle Speed Sensor' or 'VSS'
Since you didn't say 'WHY", perhaps this link will help:
Troubleshooting the Fiero Speedometer System
http://www.fieros.de/en/articles/speedo.html
1MontanaFiero
Report this Post04-29-2024 06:13 PM Click Here to See the Profile for 1MontanaFieroSend a Private Message to 1MontanaFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I’d like to change my tires from 14” to the 15” tires. Will the auto trans vss work on the 4spd manual trans?
Total ratings: 206
Report this Post04-29-2024 09:08 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, it will not.
With that said, I put 225-60-15's on the rear of my 86 SE (V6/4spd 215/60/14) and didn't change the gear in the four speed. It wasn't that far off, with the 14's the Speedo read a bit low, with the 15's it was a bit high.
[This message has been edited by olejoedad (edited 04-29-2024).]
