  12v Air Conditioning.
12v Air Conditioning. by Chris Hodson
Started on: 05-23-2024 10:20 AM
Replies: 3 (128 views)
Last post by: Chris Hodson on 05-24-2024 03:26 PM
Chris Hodson
Total ratings: 54
Report this Post05-23-2024 10:20 AM Click Here to See the Profile for Chris HodsonSend a Private Message to Chris HodsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a large step van that did not come with an air conditioner. I took a chance on one of these China 12v units. The one I found was about 400 shipped.
Look up 12V Mini Split RV Air Conditioner 12000Btu A/C Fits Semi Trucks Bus RV Caravan on Ebay.
My Fiero has ZERO AC components and ZERO Frunk. I can only imagine there are a handful of people like me out there lol. This system could easily be modified to fit into a Fiero & I might just do it vs sourcing all the stock-ish parts to make it happen. It's frigid AF, its quiet, runs on 12v. Not sure how long it will last but we shall see.
Hope this helps someone.
[This message has been edited by Chris Hodson (edited 05-23-2024).]
Total ratings: 568
Report this Post05-23-2024 03:26 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unless you have Upgraded the Alternator & more to handle "Current (A): 60-80A" can/will cause major electrical problems.
Skipping wiring problems...
Even w/ 105A CS130 on V6 or 4 Cyl will very likely know when 60-80a load kicks On. More so at Idle or in slow traffic because Advertised Amps is Peak Amps & only get that driving > 35 mph or even faster. Not just an "old car" problem, many current models have Factory installed 100+ amp alt's & w/ a larger battery to hope has enough power @ low speeds. Larger Battery is often physically bigger but often have ~ same CA CCA rating to get Way Longer Reserve Capacity even before Auto Stop the engine @ every stop sign to keep EPA happy.
Because even tho the newer cars may have ~ same power used in old cars, the multiple Computers in them often get very unhappy just seeing ≤ 12v setting DTC to 1 or more stop working for any "Low Volt" condition.
richard in nc
Report this Post05-23-2024 05:34 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
so you are saying that 12 volt ac will cool the inside of a step van?
Chris Hodson
Total ratings: 54
Report this Post05-24-2024 03:26 PM Click Here to See the Profile for Chris HodsonSend a Private Message to Chris HodsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you are able to chop this up and fit it into a Fiero I'm just assuming you would also be aware of supporting mods I've got this in my 2007 International 1000 series utilimaster 1652 and it's doing great! I'm building a battery bank so I can run it longer without the engine on.
