{EDIT}
Problem solved. I found the autopart rental gauge was broken. I borrowed a different one and it works.Hi guys, I have no idea what I'm doing wrong here but I expect it is something simple. Background - I'm new to Fiero and car mechanics in general but trying to learn and using the Fiero as my classroom...
I need to test the fuel pressure in my v6 1988 Formula. I borrowed a fuel pressure test kit from the autoparts store and found the test valve. I don't think I need any of the adapters, so am using the valve end attached to the gauge. I thought it was just a simple screw it on and it shows the pressure. But when I get it on there, nothing. Started the car, still nothing. If I poke the stem inside the pressure valve, gas squirts out so I assume it is under pressure and should show something. So, based on that assumption, I must be using the gauge wrong. But it looks so straightforward I'm stumped as to what I'm doing wrong. See photo attached of the end I'm trying to screw onto the test valve. Maybe I need one of the adapters but none look like they would work.
[This message has been edited by danahart (edited 05-29-2024).]
