What's the latest on plugs and wires? I'm at 107,000 miles and there are a couple of mouse chews showing up. No obvious symptoms but .... I think it's time.
bigger the better for wires in my experience with Gms at this point. also the auto parts store wires don't fit right. I forget the plug specified but for the area I'm in I decided to go a step hotter because of the higher ethanol content of the Gas to try and help keep carbon out if my cylinders and it's been working though I think my injectors hate the new 15 percent mix they put out everywhere
Bigger, meaning thicker insulation?
Auto parts stores wires don't fit?
Ethanol content effects plug temp range?
Your injectors "hate" 15% ethanol?
I'm looking at AC Delco "Professional", 8mm, silicon insulation with fiberglass reinforcement, specified for a 2.8 Liter Fiero V6, and Delco platinum plugs for the same engine, from NAPA auto parts .... because the local Pontiac dealer closed. ( !! ) Am I halfway on the right page or not? Anybody wanna jump in?
We have been using Summit Racing wires for years in the shop - excellent quality, easy assembly, great exterior burn resistance and they are available in red
yeah thicker insulation, I like just buying the holley 10 mm wires on clearance and shortening them since the auto parts stuff is either way too long or 3 inches too short to route properly. yeah? ethanol changes the speed and temp of the combustion cycle meaning I need to go up or down a heat range to keep carbon down especially when my state jumps from 5 percent to 15 percent which is enough to start damaging the shellac coatings in older gm injectors
Hey Yellow, did you ever end up running Seafoam? Just curious...
I'm a bit partial (I do work for Standard), but these are great wires at a great price - including the option of ceramic boots. These were developed (and still used by some) N@SC@R teams. We don't advertise as such because we would have to pay to use a certain trademark. I think some folks pass on them because they are "too cheap" on RockAuto.
My dad has those, and I really wanted to buy them, but I wanted/needed red cables, ended up spending $100 on Taylor red cables, but if you could offer those blue streak cables in red, I would turn around and buy them tomorrow. I'm sure many other customers would prefer the red cables to, as that is the factory color.
Also, it wouldn't hurt to clear coat/paint the external core on this: STANDARD MOTOR PRODUCTS DR37, ignition coil, as it flash rusted within a few days, which really doesn't look good.
You're probably not "the guy" to talk to about this, but if you were able to pass this information on, Standard would gain more customers, and happier ones (ignition coil cosmetically rusting is horrible for customer satisfaction)
I ended up with Standard Motor Products PN #5543. The specs look very similar to the fancy ones at half the price. Also the wire lengths listed in the spec sheet are very, vary close to the OEM numbers. They are 7mm so they fit the stock separators. For plugs I went with ACDelco Platinum. The cap and rotor are Delco. The new parts should arrive tomorrow.
My original wires went 107,000 miles and only leak where the mouse chewed the insulation. No visible arcing in the dark but obvious when I touched the mouse bite. The plugs in it are Bosh with a center electrode and 4 ground tabs instead of the typical 1. ( ?? ) They are still light tan and not very worn.
I think the new stuff will be just fine. Am I missing anything?
Original 36 ish year old wires with 107K? I think ANY replacement wire set will be an improvement! My relatively new to me '88 GT that had been sitting for 13 years before I got it received original ACDELCO R42TS plugs and the above mentioned Standard Motor Products wire set part #10057. I re-sized the wires as most are too long. It was actually relatively easy to do with a little youtube help and proper tools. Other than color correct, they seem like an exceptional upgrade over stock for relatively cheap. So far with 1K miles on it I have had no issues. I have learned in the past that anything other than stock plugs invite issues with other Fiero's I have owned. I tried Rapid Fire plugs and / or Platinums way back when and it was a disaster. Stick with OEM plugs. Seriously. That is my experience. Yours may be different. Best of luck!
[This message has been edited by FormulaGT (edited 06-27-2024).]
Hi.
Yeah .... it is remarkable. The old plugs really do look fairly OK. In the 60's 100 K was pretty much time for what was called an "overhaul". Spark plugs were consumables back then. Those of us on a budget would clean and re-gap them. Does anyone on the forum remember breaker points? Anybody still have a point file in their toolbox?
Yellow is coming out of a 5 year coma from being on jack stands outside. ( !!! ) He is cleaning up nicely but there are some issues popping up. I haven't installed them yet but I'm sure new plugs and wires will be OK.
Tach/Dwell meter, points files, feeler gages for setting points, various counterweight and spring sets for setting rate of advance.......
Yeah, I got it all.
Need some drum brake tools? I can help there as well.
I have a "set ?" of points in my toolbox. The only car I've ever owned that used this, was my 1973 VW Bus. I've owned some fairly old cars (I got my license in 1996), but never really had much experience with them. I know you're supposed to use a feeler gauge to measure the distance (or dwell?)... but I don't think I've ever replaced them.
I've been planning on replacing it with a Petronix ignition, but part of me keeps it in there in case the aliens come down and blast the planet with EMP waves. I'll need my VW Bus to still be driveable so I can get away from the zombie hoards.
Yeah, I got it all.
Hi
I retired from drum brakes. No more drum brakes. I really like my ventilated disks. " ..... for setting rate of advance". These kids today have no idea what they have available to them. Does your Tach/Dwell use vacuum tubes? Someone might actually have one that does. I'm sure that you have a stethoscope and a hiss tube too.
