  Transmission Bracket (?) Identification
Transmission Bracket (?) Identification by Noah3.0
Started on: 07-15-2024 12:21 AM
Replies: 6 (156 views)
Last post by: fierogt28 on 07-31-2024 07:41 PM
Noah3.0
Report this Post07-15-2024 12:21 AM Click Here to See the Profile for Noah3.0Send a Private Message to Noah3.0Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 1988 GT 5-speed I've done a clutch swap on.
Unfortunately, the time between when the transmission came off and when I put it back on was a few months longer than I planned so I've had to figure out how I'd organized all the parts I removed.
I'm unable to make out a part number and cannot for the life of me figure out what this bracket/mount is or where it's supposed to go.
If anyone here knows what it is/where in the service manual it's referenced, any help would be appreciated!
jelly2m8
Total ratings: 243
Report this Post07-15-2024 01:43 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
It's been awhile and many Fiero's don't have that any more, If memory serves me correct, that bolts to the transmission, down low on the outer rear of the case. I believe it act as a bumper to the cradle under hard acceleration. somewhere under and behind the CV axle output of the transaxle case on the left ( Drivers side)
[This message has been edited by jelly2m8 (edited 07-15-2024).]
Total ratings: 199
Report this Post07-15-2024 08:21 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
That's wild! I've never seen that before, but I don't remember seeing that on my auction 5-Speed 87 SE/V6 that I stripped. Was that an 88-only thing?
Noah3.0
Report this Post07-18-2024 08:58 PM Click Here to See the Profile for Noah3.0Send a Private Message to Noah3.0Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the replies! Based on jelly2m8's description, I was able to notice that the bracket's mounting holes line up perfectly with the two bolt holes for the rear transaxle mount on the driver's side, thereby likely bolting to the transaxle along with the rear mount.
When oriented that way, the bracket's rubber side sits about 1/4 inch above one of the lateral link brackets on the cradle, so I think an acceleration/torque bumper is exactly what it is.
jelly2m8
Total ratings: 243
Report this Post07-21-2024 02:26 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yep that's it, now I remember thinking ' I have to take those bracket bolts back out: :P
[This message has been edited by jelly2m8 (edited 07-21-2024).]
jelly2m8
Total ratings: 243
Report this Post07-21-2024 02:27 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
jelly2m8
Member since Jul 2001
I think it's an 88 Getrag only thing.
fierogt28
Report this Post07-31-2024 07:41 PM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
That bracket with the rubber pad was a Getrag 88 thing.
I assume because the cradle design was different this was used.
I don’t know were the pad would have touched on the pre-88 cradle.
I have never seen this on an 86-87GT Getrag Fiero.
One my old 87GT or online pictures over 30 years now.
I’m very specific and remember 88 parts / changes, to earlier Fieros.
