Finished with the rust hole in the a-pillar and pass side jacking area. It's like nothing happened!
Next I tackled the passenger side AusFiero Stage II body kit.
I had to figure out what to do with the front fender as there is an awkward gap.
So I decided to use the stock molding and cut it to the same angle as the molding that will be mounted to the door.
Marked and cut:
In order for the molding to contact the fender I cut out a corner on the rear edge and melted it together. I didn't take pictures of the completed melted area and it turned out nice.
This is my weapon of choice. It has a 35 minute working time so plenty of time to bond a panel to a door.
Used some fiberglass matting and mixed it in with the panel bonder and filled in the holes on the fender.
Put some adhesive on the back of the panel
And bonded it to the door. Learned lots of lessons here on applying this, how to smooth it and how much to apply.
Then bonded the little molding I modified.
I'll be riveting the molding to the fender in the original location in case it ever decides to come off. The door is on it's own I decided not to resin in studs. The adhesive seems pretty strong. I wiggled the door and banged it around a bit and it is holding well.
Finished cleaning up the front area. I found some new foam (1/2" weatherstripping) and applied to the the cover on the latch. I then proceeded to put together the rest of the windshield wiper area components and is now complete.
The rear bumper I picked up ended up painted 3 times. Originally red, then black then white. Took days to sand.
Same as the wing and wing stands. Sanding off silver, black and red. All the black and red paint was shiny and not sanded. Whoever painted this both of them did the bare minimum. As I was sanding the black layers were peeling off the red.
Had to bond in a new nut on each side as they broke loose when removing the wingstands. The panel bonder (shown in the pic) can be very sensitive to mixing and for some reason I couldn't get it to cure hard to hold the nut in. I tried 3 times! JB Weld worked like a charm and is permanently bonded to the wing.
I will be painting the wing and wingstands together as one assembly. I just had to get all those layers off.
Bonded the other body panels on the driver side. Obviously I cut the fender molding to complete the profile
The driver side is MUCH more challenging than the passenger side as the door is not lined up properly and I cannot seem to use the adjustment method on the hinges to get it to line up. So I had to make sure the panels were bonded onto the door so that one day when or if I figure out how to align the door to the car that the panels should line up properly.
A lot of time on the front fascia. It was heavily dented on the lower drivers side corner when I first saw the car so many years ago and using a heat gun, autobody dollies and lots of patience I was able to get the RIM to conform 98% of the way.
I don't have good pictures of before but you can see the "ring" where the entire corner was inside out.
There is a hundred little chips, dings and cracks in the bumper I will be using the panel bonder to fill in. You can see the entire front is littered with damage.
On another note the decklid and hood are finished. For the decklid there was around 10 decent cracks and 2 tears in the support structure of the decklid. After all the crack repair and straightening it looks fantastic and is straight! I cannot find the pictures and I have put them on the car for now so I will take pictures again when I have them off. The epoxy primer/top coat used looks near identical to the stock coating.
More to come! I have to sand the notchback clip, repair the holes where the sail panel clips go into and finish the repairs on the front fascia and then it's primer time.
