  Engine Running Rough /Wrong Tach Reading
Engine Running Rough /Wrong Tach Reading by Wacko1Jacko12
Started on: 07-17-2024 09:19 PM
Replies: 15 (243 views)
Last post by: Yellow-88 on 07-24-2024 03:26 PM
Wacko1Jacko12
Report this Post07-17-2024 09:19 PM Click Here to See the Profile for Wacko1Jacko12Send a Private Message to Wacko1Jacko12Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi everyone,
I have a 2.8L V6 Formula, I have been having problems where it will start up, it sounds like the engine is not idling correctly (going in and out). When I drive it around for about 10 minutes and then put it in park, the engine will just die and I can not start it back up after like 30 minutes. The tachometer reads 0 most of the time when driving, when I drive it and apply the break the tach will read an actual value. I took it to a shop and they found a vacuum leak where someone before me removed the EGR tube without properly plugging it up. The shop installed a brand new TPS sensor as well and properly plugged the EGR hole under the manifold (i hear no whistling now). The shop checked the fuel injectors and they were all in working order and they checked the fuel pressure (good fuel pressure). Engine sounds better but still has the same issues.
If anyone has any suggestions on what to look for/check I would greatly appreciate it.
Some things I have checked/done:
- Used TunerPro to check values and messages (no faults/alarm and no messages popped up).
-Person before me reprogrammed the chip (i am guessing that because I have no EGR and yet no alarms for it).
- Checked voltage at ALDL for the fuel pump (it read 11-12V) and I can hear the fuel pump when turning the key.
- I installed a new fuel filter.
- A new O2 sensor, MAT sensor, and a TPS sensor.
- Engine has been timed (checked by two shops).
- New spark plugs, cables, ignition coil, tach filter, entire distributor (this was installed by a shop and checked by another shop).
Cliff Pennock
Administrator
Total ratings: 699
Report this Post07-18-2024 03:45 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would replace the ECM for a stock, non-modified one. You don't reprogram a chip just to get rid of an error. So if you get no errors, and no code 12 if you jumper the ALDL connector (and the bulb is of course not removed and still working), then either the ECM is shot or the EPROM was reprogrammed for accommodating some weird modifications to the engine which are probably no longer there.
jelly2m8
Total ratings: 243
Report this Post07-18-2024 04:14 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
I agree, first step is to replace the ECM or at least the Eprom with a Factory one.
After that it sounds like a classical ignition module issue.
Wacko1Jacko12
Report this Post07-18-2024 12:30 PM Click Here to See the Profile for Wacko1Jacko12Send a Private Message to Wacko1Jacko12Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is there a good way to test the ICM with a multimeter? Mine is brand new, but sometimes new does not mean its good. After that more than likely I will buy a new computer. Because the previous owner did a EGR delete I will still have to reprogram the chip to ignore the EGR and the EGR solenoid. But at least I can finally see what my faults are.
Report this Post07-18-2024 08:36 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pull the tach filter & leave it off.
See https://web.archive.org/web...t/~fierocave/hei.htm
clean/fix all grounds bolted/screwed to block etc then coat w/ silicone or permatex green brake grease.
See https://web.archive.org/web...ierocave/ecmwire.htm
[This message has been edited by theogre (edited 07-18-2024).]
La fiera
Report this Post07-21-2024 04:48 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have the ICM tested at your local store.
Report this Post07-21-2024 05:03 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unless the ICM is ACDelco, it's probably crap. The no-name ICMs don't seem to be up to the task.
If you get the ICM tested, make sure the test is done over and over. It needs to get good and hot, as the ICM gets very hot while in operation on the engine, and it's heat that kills 'em... especially the no-name ones.
Wacko1Jacko12
Report this Post07-21-2024 05:14 PM Click Here to See the Profile for Wacko1Jacko12Send a Private Message to Wacko1Jacko12Edit/Delete MessageReply w/QuoteDirect Link to This Post
The Icm appears to be not the issue, I went to O’Reillys and advance auto parts near me, and they said they cannot test them. So I decided to buy another new ICM. I Installed it today and still have problems.
I think my plan now is figuring out if the ECM is bad, I cannot see any codes because my SES light does not come on. However i can connect with usb to ALDL using the software tunerpro and go online with it. Maybe the wiring or bulb is bad to the SES light?
Report this Post07-21-2024 07:33 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the SES bulb doesn't illuminate when the ignition key is turned to Run (not Start), then you need to at least check the bulb.
Wacko1Jacko12
Report this Post07-22-2024 12:14 PM Click Here to See the Profile for Wacko1Jacko12Send a Private Message to Wacko1Jacko12Edit/Delete MessageReply w/QuoteDirect Link to This Post
You are the man Patrick! Found that half of my bulbs were missing. I put in a bulb and now my SES light is on. Error code is 22 (TPS low voltage). The shop replaced this sensor, maybe the connector is bad or the sensor is not set right?
Report this Post07-22-2024 04:26 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
A slight adjustment may be in order.
Originally posted by Patrick in This thread:
Some people will describe bending the lever to get the correct voltage. I like this alternative method better. Go to 2:50 on the timeline.
Wacko1Jacko12
Report this Post07-22-2024 07:53 PM Click Here to See the Profile for Wacko1Jacko12Send a Private Message to Wacko1Jacko12Edit/Delete MessageReply w/QuoteDirect Link to This Post
[QUOTE]Originally posted by Patrick in This thread:
[/QUOTE]
I checked the TPS sensor and I am reading 0.02V going to ECM, In the video it says to bend the tps to get it at the correct voltage. I noticed that when I took the TPS off, the lever behind it appears to be tapered with based on the marks. I feel like I am having to bend the TPS sensor lever oddly alot. Could I also adjust this as well or is this a bad idea? I rather ask someone than be sorry.
Report this Post07-22-2024 08:41 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you not watch the video??!!! That's not what was stated at all!!!
[This message has been edited by Patrick (edited 07-22-2024).]
Jason88Notchie
Report this Post07-22-2024 09:20 PM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Umm.....where is the TPS?
Wacko1Jacko12
Report this Post07-22-2024 09:23 PM Click Here to See the Profile for Wacko1Jacko12Send a Private Message to Wacko1Jacko12Edit/Delete MessageReply w/QuoteDirect Link to This Post
I got the sensor set right, I didn’t touch what was in the photo at all. Rewatched the video and it made sense. Thank you for the video. It is reading the correct voltage right now.
Yellow-88
Report this Post07-24-2024 03:26 PM Click Here to See the Profile for Yellow-88Send a Private Message to Yellow-88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Be aware that the ECM "sees" the throttle open a 1.25 volts. The closer you are to that number, the more "instant" response will be when the throttle opens.
Of course we're talking about milliseconds, so this is just information about the TPS closed throttle setting. I set mine at 1 volt.
