| quote | 2000RagTop: yes, insert a flathead screw driver in between the coupler and "lightly" spread it apart, not a lot, just a little! This should release it........ |
88 steering rack removal- stuck by Scottzilla79
https://www.fiero.nl/forum/...160323-2-127920.html | quote | Raydar: Once you remove the {plastic front compartment} tub, you can just climb in there and remove the steering rack fasteners.
The pinch bolt is covered by a rubber sleeve that keeps water out of the universal joint.
Once you push the sleeve up out of the way, jam a long screwdriver through the universal joint to hold it out of the way. Then you can get to the bolt.
You have to take the pinch bolt all the way out. It's threaded through a notch in the side of the pinion shaft.
[This message has been edited by Vintage-Nut (edited 07-20-2024).]
