  Fiero store fuel sending unit too long?
Fiero store fuel sending unit too long? by Wayne Renninger
Started on: 07-23-2024 04:18 PM
Replies: 11 (317 views)
Last post by: saving_rossi on 11-04-2024 11:18 PM
Wayne Renninger
Report this Post07-23-2024 04:18 PM Click Here to See the Profile for Wayne RenningerSend a Private Message to Wayne RenningerEdit/Delete MessageReply w/QuoteDirect Link to This Post
The new fuel sending unit is too tall to fit in the tank? Anyone else have this problem, and how did you correct it?
cartercarbaficionado
Report this Post07-23-2024 07:22 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
picture. they may have sent you the wrong year one
Wayne Renninger
Report this Post07-23-2024 11:22 PM Click Here to See the Profile for Wayne RenningerSend a Private Message to Wayne RenningerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I called the Fiero store, they said they sold hundreds with no problems, I measured the old unit ,about 1/2 '' shorter. The Fiero store says the only differance is between 4 and 6 cyl wiring? A freind bought the one from Rodney Dickman , is 1/2' shorter and comes complete with evrything about $100 cheaper. I plan to cut the stainless tube and reweld the mount .
Report this Post07-24-2024 05:47 AM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
unfortunately they lied to you as they have been to me recently.
they did sell a 87-88 unit to you or decided to let their manufacturing get away with making parts wrong again (so far its 4 speed v6 cables, all the relays for the early headlights, the entire bushing kit for the 88, the upper balljoints for a 88 actually don't fit and are in full contact with the frame at full droop and mostly bottomed out. etc.)
I wish for the premium they charge they would actually test fit the parts coming off assembly semi regularly for proper fitment
Report this Post07-24-2024 01:50 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The early Fiero gas tanks were ten gallons. The later ones were larger at 12 gallons. Could that be the difference in the sender that you're using. There were also reports of the float sticking up on some of the Fiero store units. I would make sure that the float sits exactly as it did on the unit you removed.
Report this Post07-24-2024 03:00 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe.
The two tanks are roughly the same dimensions but later tank has different fill port plumbing to fill the tank w/ more liquid fuel & move most of the "free space" that allows liquid to expand safely to the aux tank under the body on the right side of car to allow 11.x fuel cap.
Minor difference in just location @ the end in the tank of the big Liquid Fill line &/or Fill Vent line can set max liquid before Station Pump nozzles trips off.
Related ⚠️ Warning: If the pump assembly fails to seal, more so on 87-88 tanks, then Very Easy to have Gas on the pavement when you fill the tank. Worse if you try to "stuff" the tank even a little after the station nozzle trips auto shutoff. That's how I "found" the tiny leak in https://www.fiero.nl/forum/F.../HTML/146198.html#p4 because 87-88 tanks next to zero "free space" & pin hole size leaked enough to stay put to allow evaporation before doing anything.
Total ratings: 200
Report this Post07-27-2024 04:46 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
The new sending unit is vastly better quality (in my opinion) than the old one; however, it is a little bit longer than the original 84-86. This is not a huge problem, really... you just need to bend the bottom of the sending unit slightly so that it doesn't push against the bottom of the tank. My daughter did this for her 1985 Fiero, and it fits just fine.
saving_rossi
Report this Post11-02-2024 04:00 AM Click Here to See the Profile for saving_rossiSend a Private Message to saving_rossiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I’m having the same exact issue. I’ve bent it a good amount and it still pushes..is it ok if it pushes a little? Will that create a pressure issue with the return line? It isn’t pushing too much but it’s making contact with the bottom of the tank.
Total ratings: 200
Report this Post11-02-2024 08:48 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
It's made to work for both the smaller 84-86, and 87-88 tanks (which are larger). There is a slight size difference of course, and the issue becomes installing it in the 84-86 cars.
The one thing you want to make sure of though, is that the fuel sock (which installs on the bottom), you push it down too far, and you'll basically block the fuel opening. My daughter installed hers pretty tight... and the car runs just fine. just try to bend it a little bit to give you a bit more clearance, it can be snug.
saving_rossi
Report this Post11-03-2024 07:25 PM Click Here to See the Profile for saving_rossiSend a Private Message to saving_rossiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I appreciate this response. After reading it I went and put everything back together..the pump loses fuel pressure immediately (drops to 10 PSI when I shut off the car and then to zero). When the car is running it holds about 32 PSI, I haven’t tried putting it in gear yet.
The tail pipes alternate smoking thin brownish exhaust. Not sure if that because of a lean condition or because it’s been sitting for a month.
Report this Post11-03-2024 07:57 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
...the pump loses fuel pressure immediately (drops to 10 PSI when I shut off the car and then to zero). When the car is running it holds about 32 PSI
Seems to me you've still got fuel pressure issues.
saving_rossi
Report this Post11-04-2024 11:18 PM Click Here to See the Profile for saving_rossiSend a Private Message to saving_rossiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes I literally changed out everything every component. New pump, new assembly, new lines, refurbished tank, new hoses, new injectors, new fuel pressure regulator. The fuel pump is now making a strained sound when I prime it, and stalls if I stop and also have AC on. I am thinking the long assembly is what’s causing this now. I don’t understand how it loses pressure so fast when everything is replaced
