  Throttle body heater delete (Page 2)
Throttle body heater delete by Yellow-88
Started on: 08-29-2024 06:31 PM
Replies: 41 (500 views)
Last post by: ron768 on 09-09-2024 03:01 PM
Yellow-88
Report this Post09-08-2024 09:19 AM Click Here to See the Profile for Yellow-88Send a Private Message to Yellow-88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Here's one for the hard core nerds. Basically what it says is that pressure change in a gas is related to movement of heat. It explains why venting a high pressure pneumatic cylinder to ambient gets cold and probably why engineers took no chances with our little throttle bodies.
I'll loose the tubes and void the warrantee. What was the warrantee on a Fiero anyway?
https://ls1tech.com/forums/...intake-air-temp.html
ron768
Report this Post09-09-2024 03:01 PM Click Here to See the Profile for ron768Send a Private Message to ron768Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Yellow-88:
Why would you have an EGR with no vacuum line? Yeah, you do need a cold start injector. I think you mentioned once that you have to crank a long time to get started. Could that be the problem?
If you do 7730, you loose the cold start injector.
