  88 rear caliper retracting TOO far!
88 rear caliper retracting TOO far! by ricreatr
Started on: 09-01-2024 07:13 PM
Replies: 3 (180 views)
Last post by: ricreatr on 09-06-2024 09:26 PM
ricreatr
Report this Post09-01-2024 07:13 PM Click Here to See the Profile for ricreatrSend a Private Message to ricreatrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lot of threads about rear caliper pistons not retracting, this not that! Actually had brakes and park brake all working top notch and went to the track. (Waterford hills). Worked great first session, second session, pedal started dropping a ways. Fortunately noticed it before getting on the track.
Finally noticed the left rear caliper piston retracting way too far after pumping brakes. Actually, watched the piston retract for five seconds. Ended up retracted a good 3/16, and bad enough the red brake light started flickering.
Anybody see this before?
I am about to take the caliper apart. Kinda hope to see a seal cooked or something like that.
[This message has been edited by ricreatr (edited 09-01-2024).]
cartercarbaficionado
Report this Post09-02-2024 11:34 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've encountered this on my s10 blazer. you have a leak in the caliper and master cylinder for the quick take-up system the fiero can be equipped with. our 88 ironically has thr opposite issue of staying in full contact randomly (something to do with the parking brake system I haven't quite figured out yet)
Mickey_Moose
Total ratings: 145
Report this Post09-06-2024 03:43 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
The piston would have to rotate in for it to retract out too far if it was working correctly prior. Now sure how or why it would do this.
ricreatr
Report this Post09-06-2024 09:26 PM Click Here to See the Profile for ricreatrSend a Private Message to ricreatrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, it seems weird there was no rotation. That set of pads had the nubs on the back to stop rotation.
I am digging way back in memory, the quick take up was for the drums, no? There are no external leaks. I need to see some diagrams.
Took the caliper apart. No cooked parts. Only problem was some gray sludge in there. Reassembled, and everything is working good. Think i will pull the other side and see what it looks like.
