  Thinking about replacing seats in my 88GT, what else is out there?
Thinking about replacing seats in my 88GT, what else is out there? by phils88GT
Started on: 09-02-2024 11:53 AM
Replies: 12 (311 views)
Last post by: richard in nc on 11-29-2024 07:06 PM
phils88GT
Report this Post09-02-2024 11:53 AM Click Here to See the Profile for phils88GTSend a Private Message to phils88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I want something a little more comfortable for my 88 GT. They are ok, but are not very supportive.
Was wondering what is out there that can be made to fit without a ton of modifications? I can weld as well if need be.
Anyone got examples of non-Fiero seats you have installed in your Fiero?
Thanks!
Vintage-Nut
Report this Post09-02-2024 01:17 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Seat options... will they fit? by mptighe
https://www.fiero.nl/forum/...160323-1-089788.html
cvxjet
Report this Post09-02-2024 03:53 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
One of the problems I had to deal with on my 85 SE V6 was the seat (after 25 years) was "Too low".....There was also a tear in the side bolster.....got a passenger seat cover in good shape from JY and pulled seat to have a friend install it. Looking at the bottom of the seat- it was apparent that the foam bottom had separated from the metal pan and was sagging. My friend installed some web-straps across the bottom of the seat pan which solved the problem.
Might be something to look into....
Also, the back has a zipper at the bottom- I opened it and stuffed a folded towel in there for more back-support.
[This message has been edited by cvxjet (edited 09-02-2024).]
cartercarbaficionado
Report this Post09-03-2024 06:04 AM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks!
I've used 4th gen Camaro seats, corvette seats, and a set out of a 95 gtp and a 2001 grand prix, but the best seats I've found for a fiero have been a 84 indy seat and non worn out 86 seats. I do recommend taking your seat out and fixing the foam supports (bits of wire basically or make a plate to cover it) also if your seat adjustment wire that goes between the tracks or looks brittle now is a great time to grab 16? gauge hot wire (electric fence wire spools) and make a new much stronger one.
I've redone these seats on a very strict budget of 10 dollars and it made all the difference. I need to make a post on how to repair and make them better for cheap soon.
hnthomps
Total ratings: 50
Report this Post09-03-2024 03:44 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am using stock C4 seats on one of my cars.
Nelson
rbell2915
Report this Post11-28-2024 12:28 AM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
987 seats fit great.
Total ratings: 463
Report this Post11-28-2024 07:09 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nobody has mentioned S10 / Sonoma seats. I believe they'll fit just fine, using the Fiero tracks.
phils88GT
Report this Post11-28-2024 09:15 PM Click Here to See the Profile for phils88GTSend a Private Message to phils88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
What are those seats out of?
rbell2915
Report this Post11-28-2024 09:31 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Porsche 987
phils88GT
Report this Post11-28-2024 10:35 PM Click Here to See the Profile for phils88GTSend a Private Message to phils88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
What year was it and how hard was it to adapt the Fiero rails to them?
rbell2915
Report this Post11-28-2024 11:12 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Whatever years the 987 were made. They're all the same. It was extremely easy. I just cut the factory mounts off until I got to a spot to weld on the Fiero rails. It was a perfect fit.
Report this Post11-29-2024 02:48 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have had these mid 80s C4 Corvette seats in a couple of Fieros since 2004ish. You don't sit on these seats, you sit in them and they hug you tight.
richard in nc
Report this Post11-29-2024 07:06 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
i just installed cavalier seats last weekend.i bolted them in using the fiero mounts.you don't need the cavalier mounts.they are a little taller so now im looking through the center of the windshield instead of over the wipers.make sure to get them from a two door or they won't tilt forward.remove the seat belt loop before installing.it hits the car.
[This message has been edited by richard in nc (edited 11-29-2024).]
