Update System
  The aforementioned parking brake thread
The aforementioned parking brake thread by Doggo
Started on: 09-02-2024 04:25 PM
Replies: 17 (373 views)
Last post by: Doggo on 09-17-2024 11:29 AM
Doggo
Report this Post09-02-2024 04:25 PM Click Here to See the Profile for DoggoSend a Private Message to DoggoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys, so if you’ve been following my rear brake saga you’ll know that my next step is the parking brake, which I suspect is bad. The reason for this is that when I pull the lever, the driver’s side will retract the spring, but won’t release it when the lever is disengaged. The passenger side seems to work as intended. It’s at this point that I wanted to take the cables off and show them to you guys and ask if there’s any visual indication that they are faulty. However, there’s one problem with that… I can’t get the damn cable ends out of the clip thingy that holds the two cables together! So, I’ll ask this - is there any way to visually tell that the cables are bad while they’re hooked up to the rig? If I knew they were bad I’d just snip them out but I don’t so I don’t want to go down that path just yet. I also don’t want to go ripping up my interior to get down into the handle boot if I don’t need to. Ill post pictures of what I can see, I suppose.
BONUS QUESTION: When greasing the caliper pins, do I lube just the shaft of the pin or the threads too?
This post is part of a series of threads in which I attempt to stumble my way through an (unintentional) complete brake overhaul on my 1985 Fiero. Check out the other episodes, if you're having a brake problem, chances are I've had it too!
Episode I - Rear Brake Blues
Episode II - Destroying My Brand New Caliper
Episode III - The Parking Brake (You are here)
Spinoff Episode - At wits end (started by my partner)
Episode IV - Out of Ideas
[This message has been edited by Doggo (edited 03-27-2025).]
Doggo
Report this Post09-02-2024 06:00 PM Click Here to See the Profile for DoggoSend a Private Message to DoggoEdit/Delete MessageReply w/QuoteDirect Link to This Post
The end of the passenger side cable, the one I think is operating fine-ish (more on that later):
Where the passenger cable runs through the frame? cradle? The rubber coating is like melted here. I can peel that flap back a long ways:
More annihilated rubber coating. Again, on passenger side:
The "clip thingy", the goofy thing holding the two end cables together that I can't get off:
The equalizer:
The driver's side hose. Which, to me looks new. I'm no parking brake rubber coating expert though:
The driver's side caliper spring with cable installed. This is where I think the passenger side may be bad too. I can just ever so barely get enough cable to bring it into the lever, no matter what I do. This goes for both sides. To my understanding it should be fairly easy to get enough slack in the cable to feed it into the lever
Something I forgot to mention: I can pull the passenger side inner cable, and the spring on the cable will retract and loosen, albeit with a good deal of force.
[This message has been edited by Doggo (edited 09-02-2024).]
Mike in Sydney
Report this Post09-02-2024 09:28 PM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check Ogres cave. (http://fierocave.shorturl.com/) There are some details on the parking brake operation there.
IMSA GT
Total ratings: 250
Report this Post09-02-2024 09:32 PM Click Here to See the Profile for IMSA GTClick Here to Email IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is that spring compressed 100% with the brake off?
Report this Post09-02-2024 10:15 PM Click Here to See the Profile for PatrickClick Here to Email PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
CLICK FOR FULL SIZE
Just spread the cylindrical "clip thingy" apart a bit, and then push one of the cables towards the center to remove it from the clip.
Doggo
Report this Post09-02-2024 10:30 PM Click Here to See the Profile for DoggoSend a Private Message to DoggoEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, it’s not compressed at all. Is it supposed to be when installing the cables?
cartercarbaficionado
Report this Post09-02-2024 11:31 PM Click Here to See the Profile for cartercarbaficionadoClick Here to Email cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
The equalizer:
the spring is not supposed to be compressed that much. also just pry the clip apart with a flathead screwdriver
Doggo
Report this Post09-07-2024 08:35 PM Click Here to See the Profile for DoggoSend a Private Message to DoggoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Progress is happening here at the doghouse! I've removed the two rear cables, which was a lot easier than I anticipated after reading it was a PITA from other threads. The dog ear tab things cooperated pretty well with me and I was able to hold them down with a screwdriver while pulling the cable out. Now all that remains is the front cable.
We're a pretty good ways into it we've got the trim around the lever off and pulled the boot up to get access to the assembly and removed it's bolts.
However, now we're experiencing difficulty getting the wall trim off, the one the seatbelt is bolted to. I'm trying to follow this write up I found about taking the trim out (Redo a headliner with me) and I'm on like step 3 where he says to put a screwdriver behind the panel and pop it out - " and slip a screw driver behind the panel to release the trim fastner at ear level". But he doesn't really specify where to stick the screwdriver and just can't for the life of me figure it out myself. Here's where I think he's telling me to put it:
But I don't see how that attaches to the frame or whatever the trim is clipped to. Anybody have any advice/experience in taking off this particular trim?
Also, at the cable head in the lever assembly there's some purple silicone grease on it. Am I supposed to lube the new cables before installing them?
[This message has been edited by Doggo (edited 09-07-2024).]
Report this Post09-09-2024 04:59 AM Click Here to See the Profile for cartercarbaficionadoClick Here to Email cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been told you slide the panel and somehow the clips fall off of the body? I've just pried that clip off of the 84, I've never been able to do it without breaking it and having to jbweld it back together. luckily that rear panel only needs the rear most clips and the screw since the seat belt bolts hold it on for the post part. also you shouldn't need to remove that at all. you can just blindly shove the cable through and around and around and it'll usually enter under the carpet and can be maneuvered with a screwdriver through the carpet carefully. also if the front cable moves free I would not recommend replacing it and instead greasing and then wrapping the exposed metal with alot of vinyl tape. it keeps the salt off really well
Doggo
Report this Post09-10-2024 09:37 PM Click Here to See the Profile for DoggoSend a Private Message to DoggoEdit/Delete MessageReply w/QuoteDirect Link to This Post
By exposed metal you mean the part that’s clipped up against the wall underneath the wheel well splash shield right? And, perhaps unfortunately, upon receiving my new cables from the fiero store today, I found that they all glide infinitely easier than the ones that were already on the rig. So, I think I should go ahead and just throw the new front one in too, no? Also, I noticed that the new rear cables don’t have the springs at the end, the ones that go inside the caliper spring. Is that normal? Is it just a newer design? I can take pics when I get home from work if need be. It’s also got some rubber bits that the originals don’t have on the cables themselves.
Report this Post09-10-2024 11:01 PM Click Here to See the Profile for cartercarbaficionadoClick Here to Email cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
correct. yeah probably just replace them then. I think newer design? not sure. I don't have a bunch or cables to compare with atm.
Report this Post09-11-2024 06:54 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
This clip is on the front face of the B-pillar metal and the trim piece needs to be pulled forward towards the front of the car and not sideways into the car.
There normally is also rear window sealant at the edge by the window, so it helps to pull the B-pillar trim towards the inside of the car along the back of the window to help break the sealant bond, then pull the B-pillar trim towards the front of the car.
Mickey_Moose
Total ratings: 147
Report this Post09-11-2024 04:47 PM Click Here to See the Profile for Mickey_MooseClick Here to Email Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Removing trim: you need the remove the "coat hook" and the screw that faces the door (2 screws total). Then it just pulls out.
[This message has been edited by Mickey_Moose (edited 09-11-2024).]
Doggo
Report this Post09-15-2024 07:39 PM Click Here to See the Profile for DoggoSend a Private Message to DoggoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I thought I was done with this thread. I thought we’ll be good and get the new cables installed and everything would just work. I was wrong. Everything is hooked up, new calipers, new brake cables, but for whatever reason, the levers won’t come off the stops. Or at least, not at the same time or nearly enough. I don’t know what gives, no matter how tight or loose the equalizer is, pulling the hand brake (which is super difficult by the way) will either only slightly move the levers, or not move them at all. And they almost never move at the same time and in the same way. All the cables are snag free and move on their own when individually tested.
Report this Post09-16-2024 06:42 AM Click Here to See the Profile for cartercarbaficionadoClick Here to Email cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
huh. could you take a few pictures so I can compare it to my gt and my 84 to see what's different?
flexxmi
Report this Post09-16-2024 07:29 AM Click Here to See the Profile for flexxmiSend a Private Message to flexxmiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I recall when I first got my Fiero that I engaged the parking brake and could not figure out how to get them to release until somebody pointed out that you have to pull the handle up all the way, then press the button down and hold it as you return the handle to the downward position where it rests in order to disengage the parking brake. Quirky design!
Hope this helps (?)
Doggo
Report this Post09-17-2024 11:21 AM Click Here to See the Profile for DoggoSend a Private Message to DoggoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, this is quite embarrassing, I must admit. But I’ve never done something like this before so how could I have known I guess. Long story short there was no fluid in the right caliper, causing the lever to function properly in the fluid filled left caliper but not the right one. My plan was to get the parking brake set then bleed the brakes, so I hadn’t pumped the brakes since the new, not stripped left caliper was installed. After about an hour and a half of monkeying around with various torques and tightnesses on the levers and equalizer, my buddy and I realized some fluid in the caliper might help things along lol. Needless to say the left lever now moves back and forth as it should and fully compresses the rotor. NOW, this should be the end of this thread. And, unless something completely insane happens, the end of this job. Then she’ll be ready for a good wash and that photo shoot I’ve been wanting to do for forever! And I can go back to showing all the JDM kids at my college that America made some damn cool cars too. Thank you all again for your continued support through this, it doesn’t go unappreciated
Doggo
Report this Post09-17-2024 11:29 AM Click Here to See the Profile for DoggoSend a Private Message to DoggoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Doggo
Member since Mar 2024
Hope this helps (?)
That tripped me up too when I first got the car! I pulled the lever and it clicked then fell right back down lol. I thought great, I already broke it. Certainly an interesting design choice but perhaps a necessary one given the position of the lever and how small and low the car is.
