  5 speed gear shift assembly
5 speed gear shift assembly by Sir Sdv
Started on: 09-04-2024 09:25 PM
Replies: 2 (72 views)
Last post by: Vintage-Nut on 09-04-2024 11:13 PM
Sir Sdv
Report this Post09-04-2024 09:25 PM Click Here to See the Profile for Sir SdvSend a Private Message to Sir SdvEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello
I am in need of a 5 speed gear shift assembly. The plate where cables connect, shifting mechanism, and the stick. Does anyone know where I can source one? This is the last piece I need to complete my F23/SC 3800 swap. I've tried a few places with no luck. Is there another 5 speed assembly that can be used if Fiero one is not available. I appreciate the help.
Thanks
Steve
Total ratings: 154
Report this Post09-04-2024 10:56 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any 85-88 Fiero 4-cylinder Isuzu 5-speed shifter will work. Looks a little different than the V6 Getrag shifters, but they work the same. You can swap out the shifter lever if you prefer the height of your Getrag shift lever.
Vintage-Nut
Report this Post09-04-2024 11:13 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
And post your "WTB - 5 speed gear shift assembly" in "The Mall"
https://www.fiero.nl/cgi-bi...&number=4&LastLogin=
