  3.5 engine swap question
3.5 engine swap question by Yorgle
Started on: 09-05-2024 10:29 AM
Replies: 10 (242 views)
Last post by: richard in nc on 09-09-2024 06:58 PM
Yorgle
Report this Post09-05-2024 10:29 AM Click Here to See the Profile for YorgleSend a Private Message to YorgleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a chance to get a low-mile 3.5 and automatic transmission from a 2005 Impala for very little cash and was thinking about using it as a replacement for the Duke in my 86. It seems all of the3.5 swap info I've read relates to 3.5's sourced from Firebirds and Camaros. I assume that I'll need to modify axles, mounts and brackets and use the Impala ECU and probably a stand-alone controller for the transmission. But is there any deal breaker with this engine that I've overlooked?
Vintage-Nut
Report this Post09-05-2024 10:44 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do You Search '3.5' or '3500' ?
http://www.fierosearch.com/...5%20&Action=DoSearch
http://www.fierosearch.com/...3500&Action=DoSearch
Report this Post09-05-2024 10:52 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The GM high value engine swap has been done before but I don't know how many exist in Fiero's. If you look on You Tube you will find many swaps with this engine. While I have not done this swap it looks like many changes need to be done before this swap can be completed.( its a drive by wire engine). The good news is that some versions of this engine put out as much as 242 horsepower. If you use the engine with the GM auto transmission the OEM PCM should be able to handle the job but using it without the BCM and CANBUS inputs may prove tricky. The swaps that I have seen use aftermarket ECM's with cable operated throttle bodies.
[This message has been edited by Dennis LaGrua (edited 09-05-2024).]
Total ratings: 463
Report this Post09-05-2024 05:58 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you sure it's a 3.5? I don't see it listed for the Impala. If you have access to the RPO sticker (probably inside the glove box or console) look for LX9.
If there's a different "L" code, please let us know.
If it's an LX9, it's been done a bunch of times. You can use the donor PCM or a different one.
If it's an LZ4 (which didn't happen until 2006) then there's a whole 'nother can of worms to deal with. The LZ4/LZE/LZ9 motors were VVT.
None of these motors really have anything in common with the 3.4 Camarobird motors. Those motors had iron heads, and are fairly limited.
https://en.wikipedia.org/wiki/GM_High_Value_engine
https://en.wikipedia.org/wi...s_60%C2%B0_V6_engine
[This message has been edited by Raydar (edited 09-05-2024).]
Total ratings: 200
Report this Post09-06-2024 09:06 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just wanted to add... if it's the 3500 we're talking about, it's a FANTASTIC engine. It will bolt up to your stock transmission, and will bolt up to the factory engine mount location (from what I understand). Everything else you'll need to use from the donor car... like all the accessories, exhaust manifolds, computer, etc. You'll need to fabricate a Y-pipe.
But if you can get it in there, the 3500 is one of the smoothest / nicest engines in my personal opinion. It's really an improved version of our old V6/60s.
Yorgle
Report this Post09-06-2024 12:36 PM Click Here to See the Profile for YorgleSend a Private Message to YorgleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I talked to the seller and it's actually a 3.4 NOT 3.5. Here's a link to the facebook ad: https://www.facebook.com/ma...05a-73101d35b3e1With that being the case, would it nevertheless be a good candidate for a swap? My thinking is that it would be an inexpensive way to get a reliable runner, a 4 speed overdrive transmission AND nearly double the horsepower of the duke.
[This message has been edited by Yorgle (edited 09-06-2024).]
Total ratings: 200
Report this Post09-06-2024 01:41 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, so that's the 3400 SFI, basically the exact same thing as the 3500, just .1 liters smaller (which is basically insignificant. The 3400 SFI motor was commonly found in the Pontiac Grand Am GT in the early 2000s, and it's a fantastic motor. Like, the ONLY reason why I'm not going this direction in my Fiero, is because I want my Fiero's engine bay to look as stock as possible... so I went the more expensive route of going with a 3.4 Camaro / Firebird block, and re-using all the factory Fiero components (which produce quite a bit less horsepower than what you have).
For the most part, everything you need is there. There's just a few things you're going to have to deal with:
1 - You don't have an ECM. So you'll want to get an orignial engine harness (the one on this motor seems to have been cut), and get an ECM from an appropriate year car. In my opinion, you'll want to keep the factory ECM because it will allow you to take advantage of Sequential Port Fuel Injection, rather than Multi-Port Fuel Injection, which produces better performance and efficiency in the lower rpms (no difference over MPFI in the upper rpms).
2 - You will need to remove the power steering pump, and either install a bypass or get a shorter belt. You will probably also want to relocate the alternator further down, and can probably re-use the Fiero's alternator brackets (maybe).
3 - You'll need to fabricate an exhaust Y-pipe
4 - If you plan to use the 4-Speed automatic that's in there (4T60E), you'll want to follow this: https://www.pontiacperforma...s/4_Speed_Swap.html. If you have an 85-87, then there is no modification necessary... just need new mounts / brackets.
Finally, with 102k miles, it's probably a solid engine; however, you already have the motor out, and in my opinion, it would be worthwhile giving it a once-over. Depending how comfortable you are in refreshing it, I would replace the crank and rod bearings since you'll have access to it, and replace the head gaskets and all the other gaskets as well... and probably even replace (or have cleaned) the injectors. But other than that, it's a really nice motor.
It's an LA1: https://en.wikipedia.org/wi...%C2%B0_V6_engine#LA1
Looks like it's the 175hp / 205ft-lbs version... which is nothing to sneeze at. The Camaro / Firebird motor is stock 160hp. In the Fiero, with a shorter exhaust, you're probably looking at 180hp without doing any modifications.
Honestly, there's a few people that have these blocks in their cars, and there's several modifications, including a better cam that you can install, which should easily get you up over 200hp. Part of me wishes I went this way, I just really want to keep my Fiero looking stock, which is why I went with the Firebird Gen-1 3.4 engine.
[This message has been edited by 82-T/A [At Work] (edited 09-06-2024).]
richard in nc
Report this Post09-06-2024 06:33 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
that link doesn't work for me,
Total ratings: 200
Report this Post09-06-2024 06:40 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, fixed it. It "consumed" the period at the end, and made it part of the link, which then invalidated it. I corrected it up above... but here it is again:
https://www.pontiacperforma...es/4_Speed_Swap.html
Yorgle
Report this Post09-09-2024 10:54 AM Click Here to See the Profile for YorgleSend a Private Message to YorgleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Again, thanks for all of the great info- I pulled the trigger and bought the motor and it's now sitting in my garage. Unless the forum moderator can fix the title to this thread, I think I'll start a new thread from here on out since this is actually a 3400 and not a 3.5.
richard in nc
Report this Post09-09-2024 06:58 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
this is the most complete tutorial ive seen for doing this.i have a1989 reatta donor sitting in the yard.
