  Electric A/C Compressor in a 1987 GT (6 cyl, 5-sp)
Electric A/C Compressor in a 1987 GT (6 cyl, 5-sp) by Brian A
Started on: 09-07-2024 06:03 PM
Replies: 7 (260 views)
Last post by: cvxjet on 09-08-2024 02:07 AM
Brian A
Report this Post09-07-2024 06:03 PM Click Here to See the Profile for Brian ASend a Private Message to Brian AEdit/Delete MessageReply w/QuoteDirect Link to This Post
My a/c system is empty of all refrigerant. It was that way when I bought the car.
I pressurized the a/c system to 100 psi with dry N2. The system lost substantial pressure over 24 hours. I repressurized and searched for leaks using Big Blu on all accessible hoses and joints.
No leaks found.
The leak therefore must be in the hoses along the firewall in the front of the engine or in the compressor seals themselves. (It could be the evaporator itself, but I expect leaks there are unlikely.)
Rather than replacing the a/c compressor or try to replace those hoses along the firewall, I am contemplating buying an electric a/c compressor and putting it in the front of the car somewhere thereby eliminating all the hoses (and compressor) running to the back of the car.
(I couldn't find any threads on anyone else doing this.) (Please post links if they exist.) (And feel free to titch-titch my search effort.)
I expect I would need to increase the amperage of the alternator. At first look, I think an electric a/c compressor uses about 120w (10 amps).
Does a stock alternator in a 1987 Fiero GT (6-cyl, 5-sp manual) have spare capacity? What IS the amperage of the stock alternator?
Are there standard higher amperage alternators that fit? I read about yoga moves required to get the stock alternator out. How hard is it?
[This message has been edited by Brian A (edited 09-07-2024).]
1985 Fiero GT
Report this Post09-07-2024 06:14 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is likely a 94 (ish) amp alternator, look up the RPO codes list and compare to the sticker on the frunk, drivers inner fender, and most people are stretched pretty thin, especially at idle, with the stock alternator.
You can get the cs130 alternator from the 88 Fiero v6 on Rock auto, fairly cheap, 105 amps, and what is important, it is much more efficient, it runs cooler, and makes more amps at idle then the si (original). As for removing it, is the car manual or auto, if auto, I've heard it's a chore, requiring wheel removal, and maybe disconnecting some ball joints. If it's manual, it's doable with one person without removing anything else at all, although it is easier with 2 people (1 up top to guide, support, and start the bolts, one below to get it up to where it goes) so the alternator doesn't fall on your face (don't ask me how I know haha). The cs130 alternator will need a wiring adapter (Rodney Dickman) and the use of the 88 heat shield on the exhaust manifold, modification of the 85-87 alternator heat shield (what I did until it randomly fell off somewhere), or making your own out of sheet metal or some other cars heat shielding modified to fit (what I have now)
[This message has been edited by 1985 Fiero GT (edited 09-07-2024).]
Vintage-Nut
Report this Post09-07-2024 08:04 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Electric A/C compressor conversion? by Christine
https://www.fiero.nl/forum/...130314-2-113940.html
Electric A/C Compressor - and mounting it to the frame or cradle? by Trinten
https://www.fiero.nl/forum/...110502-2-103891.html
electrically driven AC compressor by michfiero
https://www.fiero.nl/forum/...110502-2-107662.html
[This message has been edited by Vintage-Nut (edited 09-07-2024).]
RWDPLZ
Total ratings: 305
Report this Post09-07-2024 10:18 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
You would be the first.
Brian A
Report this Post09-08-2024 12:19 AM Click Here to See the Profile for Brian ASend a Private Message to Brian AEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think I may have been incorrect in my understanding of the amperage (power) required to run an electric a/c compressor. It may be more like 60 amps.
If so, it might be best to mount a second dedicated alternator where the a/c pulley drive compressor was.
I just need to learn more about what is possible before I start scheming.
[This message has been edited by Brian A (edited 09-08-2024).]
Brian A
Report this Post09-08-2024 12:22 AM Click Here to See the Profile for Brian ASend a Private Message to Brian AEdit/Delete MessageReply w/QuoteDirect Link to This Post
Brian A
Member since Sep 2023
Excellent. THANK YOU!
... I will cease and desist with any further questions on this thread until I study the above threads (unfortunately they are 15 years old) and do some general cyphering on what has already been done and the issues.
Thanks again.
Brian A
Report this Post09-08-2024 12:24 AM Click Here to See the Profile for Brian ASend a Private Message to Brian AEdit/Delete MessageReply w/QuoteDirect Link to This Post
Brian A
Gulp.
... there may be a reason.
... although 12v a/c compressors have now come to market.
cvxjet
Report this Post09-08-2024 02:07 AM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was planning for 30 years to move to a small town in NorCal (Weaverville) The summers are HOT (95-110*) so was going to add A/C to my non-A/C Fiero...and to eliminate all the hosing and other crap was definitely planning on using an electric-powered compressor.
Sadly, I can't do the move due to having contracted Lupus from a stomach acid medicine- can't be in the sun. (Stay away from Pepcid/Prilosec/Etc...if you have stomach acid issues, take Tums/Maalox/etc that ABSORBS the acid)
