  87GT Tires
87GT Tires by FieroGT1987
Started on: 09-09-2024 11:08 PM
Replies: 10 (195 views)
Last post by: BHall71 on 09-13-2024 05:56 PM
FieroGT1987
Report this Post09-09-2024 11:08 PM Click Here to See the Profile for FieroGT1987Send a Private Message to FieroGT1987Edit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone have any experience with Yokohama Avid Touring S in stock sizes? Need to get new tires and looking at these but would like to see if anyone has experience with them.
Ben Carr
cvxjet
Report this Post09-10-2024 12:09 AM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I want to give you some info; Although Tire Rack is a pretty good website for researching tires, it for some reason will not show some tire brands/styles in certain sizes.
Case in point; I looked for 87 GT size tires (205 & 215 60-15s) and it showed a very limited number of options- and I want to make clear- the BFG T/As are not very good tires and cost a bunch!
I had recently looked for tires in a different way for another Fiero-guy, and found that General makes their AltiMAX RT45 Touring tire in the sizes you need- they are very good tires, not too expensive, and also a bit lighter than most (Especially the overweight T/As)...
On my 85 SE V6, I switched to 16 x 7 wheels and General Tires...been driving it this way for 15 years...also am using the AltiMAX on my other vehicle....good tire that lasts.
jelly2m8
Total ratings: 242
Report this Post09-12-2024 02:36 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Anything modern other than the BF TA's will greatly enhance the quarter century plus old Fiero.
jelly2m8
Total ratings: 242
Report this Post09-12-2024 02:49 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
jelly2m8
Member since Jul 2001
The Altimax line is a REALLY good , underrated tire, I've ran a few sets, I've ' upgraded to a higher brand'... I go back to Altimax's.
88Fingers
Report this Post09-12-2024 07:09 AM Click Here to See the Profile for 88FingersSend a Private Message to 88FingersEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello, I went with Yokohama AVID Ascend for my 88 GT. Very happy with them. One of the better 15" IMHO
[This message has been edited by 88Fingers (edited 09-12-2024).]
Jason88Notchie
Report this Post09-12-2024 11:42 AM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
What issues have you guys have with the BFG T/A's?
cvxjet
Report this Post09-12-2024 02:48 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally, they were "THE TIRE!!!" back in the 70s & 80s...in the 90s they had the Euro TA which was better....But around 2000-2005, they changed the TAs to just a "Classic" tire without any modern technology...and actually, they "DE-contented" them...back in the old days they were soft-compound tires that stuck good (Wear rating was horrible at 200-300) Now they are hard-compound and the wear rating is up at 500+....
Also, I was looking for tires and comparing different ones for a friend....those new TAs weigh 2-5 Pounds more than any other tire. That un-sprung and Rotational mass will KILL performance and make the car ride like a pick-up truck.
I switched to those 16 x 7 wheels and General tires back around 2010....Because of wheel lightness and smaller tires up front, I eliminated 3 lbs off each rear and 6 lbs off each front....the car drove so much better it was amazing.
Look at the newer Ford GT350 Mustang- the main performance difference between it and the "R" version is composite wheels that eliminate 10 lbs from each corner.
Wanted to add; Just looked at 215/60-15 size and the cost was $190 for the (Crap) BFG and $120 for the Generals...so pay more for less (But the name- wozzer!!!)
[This message has been edited by cvxjet (edited 09-12-2024).]
Jason88Notchie
Report this Post09-13-2024 12:58 PM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
How much for the altimax tires a piece?
cvxjet
Report this Post09-13-2024 01:25 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
205/60/15 are $115 each....215/60-15 are $119 each...that is thru TireRack....may possibly find better prices; Big O used to have higher prices but finally became competitive, so now I just go to local Big O and buy/install thru them.
Jason88Notchie
Report this Post09-13-2024 04:24 PM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for all the info!
BHall71
Report this Post09-13-2024 05:56 PM Click Here to See the Profile for BHall71Send a Private Message to BHall71Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have the General G-max 16" on my 88. Love them. Plenty of traction wet & dry and what I like a lot is they are showing no signs of dry rot. My fiero has to sit outside and after about three years now they still look good.
