  Tail light sealer
Tail light sealer by NiotaFiero
Started on: 09-10-2024 12:10 PM
Replies: 5 (231 views)
Last post by: NiotaFiero on 09-11-2024 10:28 AM
NiotaFiero
Report this Post09-10-2024 12:10 PM Click Here to See the Profile for NiotaFieroSend a Private Message to NiotaFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is best to seal rear tail lights when installing new lenses?
1985 Fiero GT
Report this Post09-10-2024 04:29 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero store sells a roll of sealant tape (basically a bead of a sticky rubbery substance), which is the original, when I did mine I used silicone caulking (window or bathtub sealant or something), and that's working just fine.
cartercarbaficionado
Report this Post09-10-2024 05:37 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
butyl tape or butyl rope. same stuff to seal the windshield
go on ebay it's about 1/8th inch tape but the actual tubes of the stuff is much better
Report this Post09-10-2024 07:34 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used 3M Window-Weld butyl rope from O'Rielly's. It was 1/4 in x 15 ft, but I had to stretch it to make it thin enough to go into the groove. I let the whole thing lay in the sun for a few hours to become good and sticky, then mated the housing and lens together. You will have plenty to do a pair of tail lights.
Vintage-Nut
Report this Post09-10-2024 10:44 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierofool:
3M Windo-Weld Ribbon Sealer {butyl tape/rope}
If you use something "dries" {i.e. caulking} - good luck to open them again!
[This message has been edited by Vintage-Nut (edited 09-10-2024).]
NiotaFiero
Report this Post09-11-2024 10:28 AM Click Here to See the Profile for NiotaFieroSend a Private Message to NiotaFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for all the info.
