  Door panel repair...possible?
Door panel repair...possible? by phils88GT
Started on: 09-11-2024 09:15 PM
Replies: 5 (151 views)
Last post by: phils88GT on 09-12-2024 10:28 AM
phils88GT
Report this Post09-11-2024 09:15 PM Click Here to See the Profile for phils88GTSend a Private Message to phils88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone ever had success with replacing the fiberboard like backing in the interior door panels? I ask because some genius who owned my 88GT prior to me had taken off the door panel for whatever reason and also the factory plastic-moisture barrier and never replaced the barrier. So, whenever it rained or the car was washed, water soaked the inside of the inner door panel. I would like to remove and replace this backing if possible because it is now falling apart.
Anyone try this before and have some tips?
Thanks,
Phil
Mike in Sydney
Report this Post09-12-2024 12:19 AM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe you'll have more trouble than it's worth because the top of the panel "rolls" over the top of the door frame. I suggest that your try to reinforce it with epoxy resin.
Clean the back of the panel and get reid of any loose felt or hanging fiber-board pieces. Lay the panel on its face, protecting the holes to keep resin from running through and getting on th eface of the panel. Rough up any smooth areas on the back of the panel and "paint" a heavy coat of epoxy resin with hardener to the fiber board. The resin should seep in and when it cure s reinforce the panel. I recommend a moderatly heavy coat because you get just one shot at getting the board to absorb the resin. A thin coat may not be absorbed to the same level but after it cures, will prevent any additonal penetration (altough you can add additonal "exterior" coats).
I've used this method to reinforce the fiber board headliner backboard with good success.
Total ratings: 329
Report this Post09-12-2024 12:22 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
That fiberboard material should still be available at Home Depot. You can try to strip off the vinyl covering and replace it on the fiberboard (difficult task) or buy new complete upholstered panels from Russ.
Fiberboard Material
Total ratings: 206
Report this Post09-12-2024 09:42 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
It sounds like you need outer dew wipes as well.
phils88GT
Report this Post09-12-2024 10:00 AM Click Here to See the Profile for phils88GTSend a Private Message to phils88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I do need them, inner and outer. Mine are shot.
Thanks!
phils88GT
Report this Post09-12-2024 10:28 AM Click Here to See the Profile for phils88GTSend a Private Message to phils88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
phils88GT
Member since Oct 2023
Fiberboard Material
Thank you for the reply!
Who is Russ?
