Loud clunk when taking foot off gas, CV axle? by Blitz54
Started on | : 09-11-2024 09:53 PM |
Replies | : 6 (126 views) |
Last post by | : Raydar on 09-12-2024 05:33 PM |
Sep 11th, 2024
Blitz54 Member Posts: 125 From: Winnipeg Registered: Jun 2017
Hey peeps. Been driving the fiero all summer, and last week I noticed a clunking happening fairly consistently. It mostly happens in first gear. Accelerating the clunk doesn't happen, but when I take my foot off the gas pedal to shift or coast, theres a loud clunk in the back. It sounds like it's in the lower right side. Sometimes it doesn't happen, but it usually does. It shouldn't be motor mounts or dog bone, I replaced those and I'm 99% sure they're still good. I haven't done the cradle bushings, but I imagine that should have a clunk noise when accelerating too if it were them, right?
Also, all the replacement options for the cv axles show 33 outer spline, and 34 inner. But a few forum posts have said it's 33 outer, but only 32 inner? I have an 86 4 speed V6. Thanks all.
09:53 PM
sleek fiero Member Posts: 375 From: British Columbia Registered: Aug 2022
Hi check that the bushing in the dogbone isn't gone to crap. this is a fairly common problem. Fiero store has replacements. sleek
10:09 PM
Sep 12th, 2024
olejoedad Member Posts: 19177 From: Clarendon Twp., MI Registered: May 2004
All Fiero manual transmission axles are the same, side to side.
09:40 AM
css9450 Member Posts: 5512 From: Glen Ellyn, Illinois, USA Registered: Nov 2002
Could it possibly be something real simple, like a loose brake caliper? It happened to me.... One bolt came out and the other one loosened just enough to let the caliper rock back and forth every time I accelerated or stepped on the brake. It was quite a loud clunk though.
10:09 AM
fierofool Member Posts: 12934 From: Auburn, Georgia USA Registered: Jan 2002
Check the torque shock to cradle bolts at the front of the engine near the oil filter. That was the source of my clunk. One of the bolts had dropped out and another was loose.
10:15 AM
lou_dias Member Posts: 5351 From: Warwick, RI Registered: Jun 2000
aka check all your mounts...
05:30 PM
Raydar Member Posts: 40994 From: Carrollton GA. Out in the... country. Registered: Oct 1999
My rear (trunk side) tranny mount was separated. If I was going slow (like in traffic) it made a clunk, every time I got off the gas.
05:33 PM
