  High power 3800 build- Skyline killer
High power 3800 build- Skyline killer by Lewie
Started on: 09-19-2024 12:21 PM
Replies: 11 (241 views)
Last post by: olejoedad on 09-30-2024 11:40 AM
Lewie
Report this Post09-19-2024 12:21 PM Click Here to See the Profile for LewieSend a Private Message to LewieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi all-
I went to my local junkyard a couple months ago and pulled a series 2 3800SC from an '03 Regal. Now, a buddy of mine is constantly ragging on Fieros, and I want to shut him up for good- (and also, everyone loves lots of power in a small car) So I've set out on a mission to make 600HP from my engine. I found this article to use as a base for my build. Have any of you built an engine similar to this/have any tips and tricks?
so far:
Stattama Turbo cam #5
Duration @.050' is 230/224
Lift is .544"/536" with 1.6 Rockers
Lobe separation is 117 degrees - $519
Requires: 150# valve springs, modified retainers-? Comp Camps OER or LS7 Lifters, Rollmaster double timing chain, machine oil pump cover, PCM tuning
PAC Valve Springs- 150#- $219
ZZP 3800 Performance lifter trays- $189.99
ZZP Hydraulic Roller Lifters- 3800- $109.99
Rollmaster double timing chain- $135.99
ZZP performance 4340 H beamn 3800 connection rods- support 1000hp- $599
ARP 3800 Head studs- $99
Oil pump kit- $114
Z3 Turbokit- (still need intercooler) $2,439
Siemens Deka 60# Injectors- E85- $317
[This message has been edited by Lewie (edited 09-19-2024).]
IMSA GT
Total ratings: 253
Report this Post09-19-2024 03:39 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
And the transmission will be what?
That's the hurdle with any engine swap. not the engine power.
lou_dias
Total ratings: 67
Report this Post09-19-2024 04:29 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
I read the article but I'm confused by the "N/A" dyno of 267/247 when what's pictured is a SC motor.
I have a Series 3 N/A motor I've been meaning to rebuild as a replacement for my now dead 4.9...
I was looking for some basic upgrades for that but I seems hard to come by as everyone just goes the S/C or turbo route.
I've found this but it seems Series 2 oriented: https://zzperformance.com/b...aspirated-top-5-mods
I'd love to have a N/A 3800 that makes more hp than my 4.9 did while only giving up 50 ft*lbs at most.
For reference, my 4.9 made 196 rwhp and 298 ft*lbs on E85. I believe it could have made 5-10 more but my tuner tends to tune rich by my standards.
Best of luck on your build!
Total ratings: 259
Report this Post09-19-2024 06:33 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oil pump kit- $114
Siemens Deka 60# Injectors- E85- $317 - these seem overly small. In your linked example they used 1500 cc or 143 lb/hr injectors
The 3800 SC engine is quite strong in stock form and would swap cams and turbo it and use the $$$ saved on transmission work.
If I was an automatic guy and looking to build a stout 3800 Turbo, I would follow this thread:
https://www.fiero.nl/forum/Forum2/HTML/145844.html
Total ratings: 329
Report this Post09-19-2024 09:34 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
A guy ragging on a 3800 Fiero? Point him to this video where Scott ran a 9.87 1/4 mile at 142mph with his 3800. That guy has nerves of steel.
Ultra Fast Fiero
If that is your target it will be a hard one to beat.
[This message has been edited by Dennis LaGrua (edited 09-19-2024).]
Frenchrafe
Report this Post09-20-2024 10:53 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I run a 400HP+ 3800 turbo setup running through a 5-speed Getrag (Yes. Getrag. You heard right. It hasn't blown yet!)
I eat Porsches and hi-power BMWs for breakfast!
Never had a Skyline line up against me. Maybe they're scared?
Ask away, I'll try to answer.
One thing I'd suggest is to reinforce the front cross member of the cradle. I cracked mine.
"Turbo Slug" - '87 Fiero GT. 3800 turbo. - The fastest Fiero in France! @turboslugfiero
https://youtu.be/hUzOAeyWLfM
[This message has been edited by Frenchrafe (edited 09-20-2024).]
IMSA GT
Total ratings: 253
Report this Post09-20-2024 06:35 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's because you know how to drive with that transmission
Frenchrafe
Report this Post09-20-2024 11:14 PM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Total ratings: 206
Report this Post09-21-2024 10:08 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
What are you considering for the transmission?
Lewie
Report this Post09-30-2024 10:16 AM Click Here to See the Profile for LewieSend a Private Message to LewieEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is what I'm going for- There is a guy in my hometown with an LS swapped Fiero, he has a 6 speed manual- I'm trying to track him down and figure out how he did it. Manual is a must. 600HP is the ultimate goal, but really anything other than the stock 75 would be great. More realistically, I want to hit 400- I'll dm you
Lewie
Report this Post09-30-2024 10:25 AM Click Here to See the Profile for LewieSend a Private Message to LewieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lewie
Member since May 2024
There is a guy in my town with an LS swapped 6 speed manual fiero, I want to talk to him about his setup. Hopefully the bellhouse pattern should be similar/same. Or hell, maybe we could swap bellhousings. I was talking with a guy who recommended (funnily enough, the buddy of mine with the skyline) taking the tranny from a turbo 300ZX and swapping the bellhousing out with the Skyline's. Maybe something like that could work?
Total ratings: 206
Report this Post09-30-2024 11:40 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The F40 variant used in the G6 Pontiac has the standard GM FWD bellhousing pattern, as does the 3800 V6 engine.
Axles and intermediate shaft are the hard to find pieces.
