  Instrument cluster mod, Sunfire but not the tach/turbo gauge pod
Instrument cluster mod, Sunfire but not the tach/turbo gauge pod by Trinten
Started on: 09-20-2024 07:09 PM
Replies: 5 (152 views)
Last post by: Trinten on 12-07-2024 09:49 PM
Trinten
Report this Post09-20-2024 07:09 PM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
So a few years ago I managed to pick up two of the Turbo Sunbird instrument clusters. While the tach & turbo gauge is neat, my main focus was the OTHER gauge pod on it, which has Fuel, Coolant, Oil pressure, and Voltage.
The swap would have let me repurpose the GT two-pod cluster to show something like Transmission temp and... I don't know, whatever would be useful.
Unfortunately, I have not been able to hunt down the connectors for this cluster, so I can't go about doing this swap (which really sucks because at the 40th I met a guy who had done this swap, and was open to giving me all the wiring knowledge I would need to get it done).
Now I've seen the threads where people take this tach & boost gauge and swap it into a Fiero cluster. So I started wondering what the challenges would be for moving the other cluster over to the tach position in the Fiero cluster instead. I suspect wiring would still be the biggest obstacle. I don't know if I could solder an insulated spade connector with a wire lead from the back of the pod, and then work out the wiring with a spade plug? I have plenty of wire in various colors and stripes, so doing a wiring diagram that can be referenced later and have unique wiring won't be tough. I don't know how difficult it would be to route out the 8 (?) wires I would need to snake through.
I saw another instrument cluster swap here where a spade connector solution was used - maybe it was the Riviera cluster swap?
My soldering skills are okay, but I thought I would ask some of the more electronically inclined guys here what they thought and point out any other technical obstacles that I am not seeing yet. You know, before I dismantle a near-mint cluster. lol
rbell2915
Report this Post11-28-2024 12:12 AM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Do you need the male end of the wiring? There is an 88 Turbo in the yard near me I grabbed the cluster from.
At another yard, there's a Sunbird as well. I'm pretty sure it has a NA 3.1 cluster, but the cluster wiring and connectors should be the same if you need something.
Trinten
Report this Post11-30-2024 07:20 PM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh man!!
Yes, the pigtails that go into the back of the cluster is what I need. If I could pull off the whole cluster swap, I'd rather do that, there's someone I met at the 40th that said he could give me the wiring diagram for the conversion (he had done the whole cluster swap).
I'll drop you a PM!
rbell2915
Report this Post11-30-2024 07:32 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
https://charm.li/
I will grab those for you next weekend. The link above should be helpful for the wiring.
rbell2915
Report this Post12-07-2024 04:52 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Connector and wiring diagram are in the mail.
Trinten
Report this Post12-07-2024 09:49 PM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks again! With that, I can see about doing this potentially new type of gauge swap.
Or if it's beyond my skills, I can try to bribe one of the other electrical experts on here to help me out. lol
