  Speedometer board
Speedometer board by itzikbns
Started on: 09-21-2024 02:08 AM
Replies: 9 (204 views)
Last post by: J Gunsett on 09-28-2024 10:17 AM
itzikbns
Report this Post09-21-2024 02:08 AM Click Here to See the Profile for itzikbnsSend a Private Message to itzikbnsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi,
I have an 86 SE 2.8, a ferari replica, I have replaced the gauges cluster with SPEEDHUT indipendent gauges with Pisa wiring harness to bridge, I need to use the speedometer board, see image below, as the amplifier, so I need to solder the wires (YEL & PPL/WHT) that are coming from the VSS to that board and get one wire with amplified signal to go to the speedometer, could you please tell me where are the points to solder? I belive that the original speedometer gets his buffered signal via the 4 bolts attaching him to the board. how can I get one wire from that?
Report this Post09-21-2024 10:06 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Forum member JGunsett may be able to assist you with your question.
itzikbns
Report this Post09-25-2024 09:54 AM Click Here to See the Profile for itzikbnsSend a Private Message to itzikbnsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, is he a member?
Report this Post09-25-2024 11:48 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
J Gunsett
Report this Post09-26-2024 10:25 AM Click Here to See the Profile for J GunsettClick Here to visit J Gunsett's HomePageSend a Private Message to J GunsettEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have a PM.
Jack
itzikbns
Report this Post09-26-2024 10:32 AM Click Here to See the Profile for itzikbnsSend a Private Message to itzikbnsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by J Gunsett:
You have a PM.
Jack
Thanks, what do you mean by PM?
Itzik
itzikbns
Report this Post09-26-2024 10:33 AM Click Here to See the Profile for itzikbnsSend a Private Message to itzikbnsEdit/Delete MessageReply w/QuoteDirect Link to This Post
itzikbns
Member since Aug 2023
You have a PM.
Jack
Itzik
Aaron B
Report this Post09-26-2024 11:05 AM Click Here to See the Profile for Aaron BSend a Private Message to Aaron BEdit/Delete MessageReply w/QuoteDirect Link to This Post
Private Message
Check your message inbox
Report this Post09-26-2024 11:06 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Private Message
Look at the very bottom Topic on the Forum page, you will see the Private Message topic box.
[This message has been edited by olejoedad (edited 09-26-2024).]
J Gunsett
Report this Post09-28-2024 10:17 AM Click Here to See the Profile for J GunsettClick Here to visit J Gunsett's HomePageSend a Private Message to J GunsettEdit/Delete MessageReply w/QuoteDirect Link to This Post
itzikbns, I see you tried sending me a PM but there was no text. Use my email address.
Jack
