  Which Wildwood Master Cylinder Model Number for Fiero
Which Wildwood Master Cylinder Model Number for Fiero by Signupacct
Started on: 09-24-2024 12:39 AM
Replies: 20 (253 views)
Last post by: pmbrunelle on 09-27-2024 06:55 PM
Signupacct
Report this Post09-24-2024 12:39 AM Click Here to See the Profile for SignupacctSend a Private Message to SignupacctEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am considering a Wilwood Master Cylinder instead of an OEM
there is no other master cylinder make that is new and made in the usa guaranteed. The AC Delco may arrive with the usa stamp or may not and the listings at summit and amazon say mexico. Shipping date is October and Summit said they may push that date further out or back order. Centric is China. A Premium also China. Raybestos is made in mexico and has the the best shipping date of just a few days. Same with front calipers.
Wilwood's are new and made in the USA.
Just got off the tech phone support line and they say they do not have a list of master cylinders for different makes and models
and therefore don't have a specific model intended for fiero and that there units are universal
They offer the following check list of questions to help determine the best unit:
Piston size and number of pistons in calipers
Master Cylinder bore size OEM
Brake Booster with Dual Diaphram
8 inch diameter diaphram
and Minimum 18 inches of vacuum at idle
And finally:
the pedal ratio (calculated using a pdf from Wilwood)
https://shop.wilwood.com/bl...and-how-to-find-them
Has anyone determined the best Wilwood unit for fiero's
They suggested the 260-8555 fwiw
Joe k
[This message has been edited by Signupacct (edited 09-24-2024).]
cartercarbaficionado
Report this Post09-24-2024 02:40 AM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Signupacct:
I am considering a Wildwood Master Cylinder instead of an OEM
Wildwood's are new and made in the USA.
And finally:
the pedal ratio (calculated using a pdf from Wildwood)
Has anyone determined the best Wildwood unit for fiero's
Joe k
their suggestions are usually pretty good. do tell them the bolt holes size needs to fit an s10 blazer since a few gm cars do use a different bolt hole pattern. just so happens the fiero and most of the late 80s-early 90s gms share until they got abs
Total ratings: 329
Report this Post09-24-2024 03:40 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will measure it later today but from memory the bore size of the Fiero master cylinder is either 1 1/8" or 1 1/4".
Report this Post09-24-2024 04:40 AM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
it should just be 1 inch. that's what I'm measuring off of a few junked ones and one that was slated to go Into a car soon
Total ratings: 259
Report this Post09-24-2024 07:18 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
You should share the year of the Fiero, as 84-87 are different than the 88s.
All the Fiero brake masters have quick take up features, which I doubt Wilwood has. This will likely mean more dead pedal travel.
84-87 is 25.4mm or 1":
88 is 23.8mm or 15/16"
If you go larger than stock, the pedal will be harder to press, have less travel, less clamp force at the calipers, and less overall braking force for a given pedal input force.
If you go smaller than stock, then pedal will be easier to press, have more travel, higher clamp force at the calipers, and more overall braking force for a given pedal input force.
For 99.9% of people, it would be best to stick with the stock diameter.
Signupacct
Report this Post09-24-2024 11:15 AM Click Here to See the Profile for SignupacctSend a Private Message to SignupacctEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry about not mentioning the year
It is a 1987 Pontiac Fiero GT with a V6
I hope that helps
I am interested in as close to oem on bore size as is possible unless the community thinks that a slightly smaller diameter might enhance brake pressure at the calipers etc.
Otherwise yes I would like OEM as close as possible
the calipers and pads are OEM no modification or conversions here.
So far the only deviations in this brake job are the SS brake lines and the wildwood proportion valve replacing the OEM proportion valve and went with the
https://www.wilwood.com/mas...rod?itemno=260-11179
only mildly irritated that wildwood won't say which unit is best fit to replace OEM
any help here is appreciated
Joe k
Signupacct
Report this Post09-24-2024 01:00 PM Click Here to See the Profile for SignupacctSend a Private Message to SignupacctEdit/Delete MessageReply w/QuoteDirect Link to This Post
Signupacct
Member since Sep 2022
Using the pdf document from Wilwood I measure the different points on figure 1 in the document.
Pivot point at the top of pedal to the mid point of the brake pedal foot pad:
P to A is 10 1/4 inch
the point at the top of the pedal to the point where the rod to the booster is attached:
P to B is 2 1/2 inch
the pivot point at the top to the top of the brake pedal foot pad:
P to F is 9 1/2 inch
If anyone else has measured these points please double check my work
I hope I understood their document enough to make all the necessary measurements
Joe k
Total ratings: 329
Report this Post09-24-2024 04:30 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is the measurement from a Fiero MC rebuilding kit.
[This message has been edited by Dennis LaGrua (edited 09-24-2024).]
Signupacct
Report this Post09-26-2024 02:24 AM Click Here to See the Profile for SignupacctSend a Private Message to SignupacctEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dennis
thank you for posting. Is that a MC rebuild kit by GM or genuine gm parts and it was the size for your OEM master cylinder ?
The diameter is not only key to making a selection of a unit from wilwood but also making sure that the correct diameter is obtained when buying a oem replacement.
Centric's are made in China so why would I want to trust their diameter in the centric graphic that was shared in a post, well intended as it may have been.
Does anyone have documentation from factory technical materials indicating what the diameter is ?
I have checked all of mine and I have not found anything in the manuals and other documentation that I have
Does anyone have WHAT THEY KNOW IS a oem master cylinder that they know was put on at the factory?
My Duralast reman (which I'm returning and trying to go with a new oem unit) measures 1.4350 inches and that is 36.45 mm. Very close to your measurement. Mine is a Duralast part # NM1988.
Duralast being autozone isn't any more reliable a source for accuracy then Centric.
In other posts it is noted that you DO NOT WANT TO GO WITH A LARGER DIAMETER PISTON SIZE as it will result in less breaking power.
And other posts say, be sure you don't inadvertently get the larger diameter bore
I wish I still had the unit that was on my car before I started this brake job from h _ _ _ ! but I turned it in for the core already.
I have a New OEM Raybestos MC39572 on the way that they say is made in Mexico and looked up the specs and it doesnt say the piston diamter
Anyone ?
Joe k
[This message has been edited by Signupacct (edited 09-26-2024).]
Signupacct
Report this Post09-26-2024 02:41 AM Click Here to See the Profile for SignupacctSend a Private Message to SignupacctEdit/Delete MessageReply w/QuoteDirect Link to This Post
Signupacct
Here is an example of a post seeking the same information and similar dilemma
Originally posted by 2002z28ssconv:
As much as I hate to start a new thread, I have been searching for hours now... I figured it would have been covered before but I sure can't find it.
Car - 88 Fiero 2.5 Auto - 100% factory stock.
Problem - Leaking rear seal on brake master cylinder.
I purchased a reman from AZ (P/N - M2357)
A knowledgeable Fiero friend told me to watch for them selling me one with the wrong bore size.
So I am verifying... maybe...
From the little I was able to find here on PFF in threads about the differences between the Fiero and S-10 masters, the Fiero master has a 0.944" bore diameter. That equates to 24mm.
The spec sheet AZ printed out for me says that their master has a 1.414" bore. So right off the bat, I think I have the wrong master.
However, I went to Advance as well as O'Reilly's and any master they brought up said 24mm/36mm.
So I'm on a hunt for what the correct bore size should be.
I suspect that the chamber for the front brakes is 24mm and the rear is 36mm. Dose anyone have the no longer available shop manual? Perhaps it would say in there. I lost my downloaded version with my last hard drive failure.
Either way I figure I'll be taking the old one apart and comparing it to the new one. I just want to try to make sure I get the right part before I tear the car apart again.
His thread ended without anyone sharing an answer
Joe k
Total ratings: 259
Report this Post09-26-2024 07:09 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is apparent I need to further explain what a Quick take up master does...
The Fiero masters have a stepped bore (two separate bore sizes) where the larger bore is only used to move the caliper pads to the rotors.
Once the pads make contact there is a pressure bypass on the large bore and the smaller bore takes over for actual braking pressure.
The smaller bore is then the source for all brake pressure through the system - not the larger one.
This was done to allow the pads to retract further from the rotors for fuel economy.
You can use a quick take up master with almost any caliper.
However, using a standard bore master on calipers designed for the quick take up master will have more dead pedal as the smaller master bore will be the only thing moving the pads to the rotor and it will take more travel than the larger bore would.
So if you have an 84-87 and looking for a non-stepped master from another supplier, you would need the 1" diameter one.
However, doing this will result in more dead pedal travel as you will eliminate the quick take up feature.
Going to a larger bore would reduce the dead pedal travel some, but at the expense of brake line pressure and result in less braking force, making the conversion a brake downgrade.
fierogt28
Report this Post09-26-2024 07:27 AM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
The 84-87 Raybestos bore diameter size is 26.400mm.
But the Centric brand MC says the bore is 25.4mm = 1”.
I can’t confirm because I never measured these 2 MC to actually see it.
These measurements are listed on RockAuto website.
fierogt28
88 GT, Loaded, 5-speed.
Total ratings: 329
Report this Post09-26-2024 08:25 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hard to figure out. I got that new piston assembly out of a Raybestos box and the measurements are shown here in this thread.. The last MC that I replaced was AC Delco. marked USA but who knows? Have had good luck with Chinese Centric products so may go with that next time. All the major brands are Chinese made. Its just strange that a large US company like Wilwood cannot recommend a direct replacement. If the replacement had a 1.43" bore it may work OK. With the S-10 brake booster you would probably not notice much difference in pedal feel.
Total ratings: 206
Report this Post09-26-2024 09:28 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
While I appreciate the effort to buy American made products where possible, in this case it seems like one would be better of buying a quality rebuilt master cylinder that is designed for the car.
Signupacct
Report this Post09-26-2024 01:11 PM Click Here to See the Profile for SignupacctSend a Private Message to SignupacctEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes I wish I could change the wording on this thread becuase I am becoming less enthusiastic on the Wilwood simply becuase they will not issue out a parts compatibility recommendation on the fiero.
Well as for remans I been to that rodeo and got the t shirt. In another post I mentioned that if the cars were just 5 or 7 or even 10 years old then a reman unit is likely not entirely worn and a rebuilding can make more sense. But over time as the units are used the surfaces wear and then rebuiding takes even more to smooth out and thus less likely to be a reliable option. Especially now that some oem units are almost 40 years old. And the core charge attracts all kinds of candidate for the reman process and the reman factory is more oriented to GET ANOTHER UNIT OUT THE DOOR kind of thing.
SOOOO! then what is the highest on the pecking order for new units. Made in the USA OEM specs. Ok let's go there. First Made in the USA: not a guarantee that any NEW unit will be made in USA and so then next down from there is Mexico and then from there China. Why USA is likely best choice, because they are more likely to appreciate what the product promises to be, an OEM replacement and likely to have the OEM specs and not have a language barrier to interpreting it. Then why Mexico over China, well some just over the border manuafacturing still has US oversight, more so then China with a language barrier.Everything is a crap shoot these days but these are my thoughts so far.
Signupacct
Report this Post09-26-2024 01:35 PM Click Here to See the Profile for SignupacctSend a Private Message to SignupacctEdit/Delete MessageReply w/QuoteDirect Link to This Post
Signupacct
fierogt28 you are on my Christmas card list.
I finally can see at least what the specs are for the bore size on the RockAuto website. Though I have not been able to find any OEM documentation that specifies that OEM is 1 inch.
But the preponderance of the evidence in that most of the units listed at Rock Auto are 1.0
Raybestos, AC Delco and Centric all list as 1.0 inch
the NM1988 which is Duralast which I have here is 1.4 inch. It goes back to Autozone.
It is listed as NM1988 by FVP and DFC and Quality Built are all listing at Rock Auto as 1.4 inch
I would like to make a post of this in a titled thread since this seems to be the best answer to the this question.
thanks again
BTW i reached out to Rock Auto by email with these question related to this and got the brush off.
But that's ok because at least their website lists the diameter and others that I have seen do not.
Joe k
Signupacct
Report this Post09-27-2024 11:58 AM Click Here to See the Profile for SignupacctSend a Private Message to SignupacctEdit/Delete MessageReply w/QuoteDirect Link to This Post
dont know why my browser is just now showing your post and that's ok
thank you for your explanation.
So after reviewing the specs on the Rock Auto site as I noted which say 1.0 for some units and which say 1.4 for other units and noting the Raybestos cited 1.0 in the description I received my Raybestos and when I opened it I noted that the diameter of the unit is 1.4 mm
So Im guessing that 1.4 is the measurement at the top of the piston and then further into the unit it is 1.0 and that is what counts ?
I am now figuring out how to get to ogre's cave to find data there.
Joe k
[This message has been edited by Signupacct (edited 09-27-2024).]
Total ratings: 259
Report this Post09-27-2024 05:38 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
All Fiero masters have 2 bore diameters.
The 36mm (or 1.4") is the diameter of the quick take up bore and this has nothing to do with brake pressure, it is for pad movement only.
https://fierocave.shorturl.com/index.htm
For the 84-87, the smaller bore is 1" and this what what actually provides the brake pressure. This is confirmed with the chart on this page:
On the 88 Fieros this smaller bore is 15/16".
Wilwood does not offer any master cylinders with the quick take-up stepped bore setup, so they can't offer a stock replacement for the Fiero without it having some type of negative performance (more dead pedal travel or less overall braking force).
If I needed one for an 84-87, I would buy this one:
https://www.summitracing.co...odel/fiero/year/1987
[This message has been edited by fieroguru (edited 09-27-2024).]
pmbrunelle
Total ratings: 63
Report this Post09-27-2024 05:59 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
According to my understanding, basically all calipers use square seals.
Would a low-drag caliper have a seal with a larger square section?
Total ratings: 259
Report this Post09-27-2024 06:35 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
My understanding is that the seal surface on the piston is the same, but the seal surface within the caliper is more of a wedge shape with a little more clearance along the sides.
http://www.remaninc.com/pdfs/lowdragcalipers.pdf
pmbrunelle
Total ratings: 63
Report this Post09-27-2024 06:55 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have taken Fiero calipers apart a few times. The seal was square. I didn't pay much attention to the groove (it's hard to inspect that area anyway).
I don't know if a conical groove requires a matching conical seal, or if it works with a square seal.
