  Rebuild 3800 to 3800sc
Rebuild 3800 to 3800sc by pizzaboy98
Started on: 09-24-2024 01:14 PM
Replies: 6 (94 views)
Last post by: Dennis LaGrua on 09-25-2024 08:09 AM
pizzaboy98
Report this Post09-24-2024 01:14 PM Click Here to See the Profile for pizzaboy98Send a Private Message to pizzaboy98Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is a possibly dumb question spurred on by my local scrapyards’ lack of inventory. Are there any block differences between the L36 and L67? If someone was able to get an L36, a supercharger, and an L67 rebuild kit would it be as strong as an L67?
I can only find naturally aspirated 3800s. Some in good condition but still. Online the costs are insane, like $1700 for a 200k SC from a clearly thrashed Grand Prix. Idk, maybe I just need to look harder or wait longer. Or look for another engine. But if I’m going to go through the effort and cost of a swap I want reliable power. This car will eventually be a daily driver.
Total ratings: 329
Report this Post09-24-2024 04:45 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are many differences in the 3800 N/A compared to the 3800SC. Just to name a few; different pistons, fuel rail, intake manifold, throttle body, MAP sensor, drive belts, PCM program and supercharger. The later series III N/A versions came with 200 HP. With some intake flow mods, exhaust work and a performance cam you can come close to SC horsepower.
pizzaboy98
Report this Post09-24-2024 05:17 PM Click Here to See the Profile for pizzaboy98Send a Private Message to pizzaboy98Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you, that’s what I figured (and then some, damn that’s a lot) but would feel foolish if I hadn’t checked. I’m not starting the project for a little bit anyway so hopefully the right 3800 comes along. If not those 2.8 rebuild kits always seem in stock.
Total ratings: 329
Report this Post09-24-2024 08:01 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Used 3800's are usually priced right. You could start with a rebuild and go performance from there. For a bargain rebuild and assuming the crank journals are OK, you could just change the pistons go turbo and make more HP than the SC versions.
Frenchrafe
Report this Post09-24-2024 09:53 PM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
.....you could just change the pistons go turbo and make more HP than the SC versions.
I'd say pistons and rods.
Then you'll be good for going higher power than SC.
"Turbo Slug" - '87 Fiero GT. 3800 turbo. - The fastest Fiero in France! @turboslugfiero
https://youtu.be/hUzOAeyWLfM
Total ratings: 259
Report this Post09-25-2024 07:00 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
It hasn't been mentioned, but the 3800SC heads are different as well. With the SC taking up space between the heads, the injectors were moved to the heads vs. being in the intake.
When people have done this in the past they refer to it as a top swap (3800 SC heads/lower intake/SC on a NA short block).
Total ratings: 329
Report this Post09-25-2024 08:09 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good point. I always wondered why the top swap was done by a few. If you decide to change the all those components to do this you will still have the NA pistons and higher compression ratio. IMO, the simple solution for N/A power (on a good quality engine) is to change to SC pistons and add a turbo. It will be a more economical approach.
