  Amazon $160 Supercharger on a Duke for 150 HP
Amazon $160 Supercharger on a Duke for 150 HP by Dennis LaGrua
Started on: 09-26-2024 09:32 PM
Replies: 7 (214 views)
Last post by: cartercarbaficionado on 09-28-2024 08:11 PM
Report this Post09-26-2024 09:32 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
This won't be a direct bolt on as some work will be required to set it up, tune it but there is an inexpensive Supercharger sold on Amazon.com that can support up to 150 HP. Its pretty low cost, around $160 and am attractive option for boosting power.
Take a look on Amazon
[This message has been edited by Dennis LaGrua (edited 09-26-2024).]
phils88GT
Report this Post09-26-2024 09:53 PM Click Here to See the Profile for phils88GTSend a Private Message to phils88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just my opinion here, but I don't think that supercharger would make enough HP to offset what it robs due to parasitic losses.
Report this Post09-27-2024 01:41 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check out Amazon for the supercharger for 2 -3.5L engines. There is always parasitic loss with a belt driven supercharger but the power they add usually overcomes that. After checking the $160 unit will only work on engines less than 2.0 L. The larger supercharger may work on a Duke engine but you would have to find a way, to add fuel, a larger throttle body, re-curve timing and not go too high on boost.
Report this Post09-27-2024 03:16 AM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
was actually considering this on a duke and it's actually pretty easy but the block needs studs since the stock head bolts are already pretty much fully yielded and won't take much more in most cases (at least with felpro bolts these days. broke a few off in my built engine and I'm still fuming)
so we (me and idiot friends) have tried doing this same thing to a ford 300. an amr 300 supercharger.making 6 psi though a dual cone filter setup will actually add around 45-60 horse if you can actually make the flow happen through the head
the solution to he throttle body an extra fuel is to cobble a 4.3l v6 throttle body on with its dual injectors (can be wired separately with a little knowledge and effort. mostly by making the second injector recive the normal pulses but interupt them with a contactor normally) to a custom intake/adapter and timing recurve is as simple as grabbing a computer/ vaccum advance distributor from truck iron duke or chipping the ecm.
Report this Post09-27-2024 10:29 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would say that you are on the right track. Are new head bolts available? If so its a good idea to change them or ring the heads. . Its logical to assume that the Duke engine can be boosted but I would say not more than about 5 psi. Boosting increases the volume of air in a given space so at low boost head porting may not be necessary. I agree that a larger throttle body and tuning retard must be used. With mods and an adapter plate a larger TB can be made to fit the intake manifold. MSD sells an ignition box that you can adjust the timing on from the dash. While I have built four boosted engines, there's no experience here to share on the Duke. Ran them hard, followed the rules and there were no blow ups. Good luck on the project.
Report this Post09-27-2024 02:51 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes and no? there are studs available but they are custom order from a different gm engine. I forget which but did use to have it written down.
also kind of a maybe statement isn't it? let's say we have 3 psi through a highly unrestricted intake into the supercharger well that will probably preform better than 6 psi through the same supercharger when it's having to work harder to draw through a much more restricted filter (source is banks power and psi being more of a statement of how much flow if you do it right) there is quite a few "gotcha" things with the fiero Iron duke specifically though. the heads are super weak and prone to cracking as there's still quite a few bad castings out there, the block itself isn't really too strong with how porous and thin it is in critical areas,they really all benefit from a girdle to help the mains not flex under heavy load (like a boosted engine) and the block should absolutely be wrapped and shrouded for safety and fire protection incase a rod decides its time to play peek-a-boo
richard in nc
Report this Post09-28-2024 07:29 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
the 2.5 has three different headbolts.the two on the forward corners have studs on top and are different lengths from each other.
Report this Post09-28-2024 08:11 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
doesn't matter with studs.
