  88 gt running issues
88 gt running issues by cartercarbaficionado
Started on: 09-27-2024 08:31 PM
Replies: 4 (125 views)
Last post by: cartercarbaficionado on 09-30-2024 07:39 PM
Report this Post09-27-2024 08:31 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
got to work helping a fiero club member today and got the valves done on his gt. it still running rich and not really wanting to idle properly. plugs got 10 minutes on em and they are completely covered in soot.
3.4l with 2.8l intake swap plus a cold start injector delete with 17 lb injectors and a stock 88 manifold and y-pipe into a ocelot exhaust. egr and systems are intact
Report this Post09-28-2024 06:34 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok more information about the issue from the last 4 hours.
a different known good map sensor, 02, icm and triple checking for leaks and I can't find any vacuum leaks and unplugging every sensor minus the 02 sensor it's still shooting for an idle around 2k and will not come down at all. started going really lean too with the proper fuel pressure and a different prom and 2nd known good ecu haven't changed anything.
yes I have blocked the iac port in the throttle body. engine died immediately.
it was running rough but after setting the tps to .38-.40 volts has the idle dead smooth minus the occasional pop
really stumped on this one
Report this Post09-28-2024 09:58 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Sep 2023
found some issues finally. oring for iac tub eand some other stuff was bad and I finally got it fixed ish?
it's running a bit lean and could definitely use some work still. did put a scanner on it (the red brick) and my 02 milivolts was around 217 after idling for a bit
map was 40 kpa at 1.61 volts at an idle of 1050-925
tps looked fine but maybe needs something
fuel pressure while running is 40
armos
Report this Post09-30-2024 06:43 PM Click Here to See the Profile for armosSend a Private Message to armosEdit/Delete MessageReply w/QuoteDirect Link to This Post
what PROM? factory 1227170 ECM (86-88 V6), 1985 V6 ECM, or something else?
factory Fiero PROMs will be a bit lean for a 3.4L, but it's probably within the adjustment range. The BLM and/or INT values should come up and the mixture would get corrected. Still it's better to tune the PROM to match the engine. ECM "learning" is very simple and limited, that's why car companies have a different tune for everything, not one generic one.
I'm not even sure the "learned" fuel adjustment sticks between restarts. It might idle lean every time you start it until it starts measuring the O2 sensor feedback.
If this is a factory narrowband O2 sensor, then once it has warmed up enough to enter "closed loop", the sensor reading will rapidly fluctuate between 0V-1.0V. It bounces back and forth in that range. Closer to 0V is lean, closer to 1V is rich. Normally the reading is too erratic to be meaningful, you just want to see it swinging back and forth.
If it's staying constantly in the low end of that range, not moving around, then the ECM might not be entering closed loop.
Closed loop means that the ECM has started paying attention to the O2 sensor and is modulating the mixture to make the O2 reading bounce up and down between 0V-1.0V. The O2 sensor doesn't work until it gets hot, that's why the ECM ignores it until it thinks it's ready to work. It also ignores the O2 whenever it doesn't want to run at stoich (~14.3-14.7:1, depending on ethanol).
One reason for not going into closed loop is if it thinks the engine is cold. On the FBA1819 for example the Minimum Coolant Temperature for closed loop is 24.5C (and it also has to run for at least 60 seconds).
If the ECM is going into closed loop but it can't get the O2 sensor reading to cross between Rich and Lean, then you should get a Check Engine code.
This is all assuming you're using a factory Fiero PROM, not something custom.
The scan tool might tell you "cross counts" - that's counting how many times the O2 sensor has crossed between Lean and Rich readings. Watching how quickly the number increases tells you how quickly the sensor is responding and how quickly the ECM is modulating the mixture.
You get something similar if you start the engine while shorting the A-B terminals of the ALDL connector (same way you check ignition timing). If you do that then the Check Engine light will flash. The light turns on when the O2 sensor says rich, and off when the O2 sensor shows lean. It should keep blinking steadily to show that the sensor is bouncing the way it should. From memory, on my car I think it blinks on-off-on a little faster than once per second.
Only problem with that test is that the timing is abnormally retarded while you're doing it, because that mode is also used for setting timing.
The diagnostic mode used by the scan tool might force the idle to 1000rpm. When running normally without any jumpers or tools, it should drop to 900rpm when warm. Is the idle dropping down like that when the car runs by itself, or is it still stuck on a high idle normally?
[This message has been edited by armos (edited 09-30-2024).]
Report this Post09-30-2024 07:39 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
car running by itself is idling at 850 with a new 02 sensor but kept having what I thought was excessive blowby. a compression test revealed a 40 psi difference between the highest compression cylinder and the lowest (140-100) so it's coming out to Be replaced.
also the ecm was using the factory 88 PROM for a federal emissions 5 speed which is correct. it ended up being the iac was bad.
I was using a snap-on red brick scanner. the road test mode allows for data logging and a live readout.
the thing that was weird is the computer was complaining about the engine not seeing enough air for the engine to idle at 850. so i tried a new map and it stopped complaining and yes the ecm was going into closed loop and open loop whenever it needed to according to the coolant temp sensor in the manifold
[This message has been edited by cartercarbaficionado (edited 09-30-2024).]
