  Alternator Question
Alternator Question by k5ahudson
Started on: 09-28-2024 06:05 PM
Replies: 7 (124 views)
Last post by: fierosound on 09-30-2024 11:46 AM
k5ahudson
Report this Post09-28-2024 06:05 PM Click Here to See the Profile for k5ahudsonSend a Private Message to k5ahudsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an 85 Fiero without AC with a 78 amp alternator that needs replacing. Surprisingly I'm finding a 94 amp replacement alternator is cheaper than the 78 amp. I don't think there is any reason I can't install a 94 amp alternator in a no AC Fiero. Correct me if I'm wrong. Thanks.
Report this Post09-28-2024 06:17 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Take it another step further... Upgrade to CS130 alternator
k5ahudson
Report this Post09-28-2024 07:17 PM Click Here to See the Profile for k5ahudsonSend a Private Message to k5ahudsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not necessary for my needs. Thanks anyway.
Report this Post09-28-2024 07:59 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
It may not be "necessary", but it's a dead simple upgrade to a superior alternator.
Total ratings: 200
Report this Post09-28-2024 08:16 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'd like to echo what Patrick said, the CS130 alternator is vastly superior. It runs cooler, runs quieter, and is more reliable across the board... likely the same cost. GM switched to them in 1988 anyway.
But to answer your question, yes... the higher amperage alternator will work just fine in your car. It's only the available amps that it can provide (if needed) and does not necessarily mean that it will be producing that full time.
1985 Fiero GT
Report this Post09-28-2024 08:43 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Go with the Cs130, there's a reason they came on the 88 Fieros, drop in upgrade, with Rodney's wiring adapter, cheaper than many of the original units, and more availability/easier to come by if needed, as well as being more efficient, longer life, and all the other benefits, if you're already modifying the cars option list (alternator amperage is a listed option on the RPO sticker) you might as well go for the actual upgrade, not the interior half upgrade.
k5ahudson
Report this Post09-29-2024 12:22 PM Click Here to See the Profile for k5ahudsonSend a Private Message to k5ahudsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
To tell the truth guys, I only want the cheapest option because I'm selling the car. If I were keeping it I would be following your advice. Going by prices on RockAuto and the additional cost of the adapter it would probably cost me another 50 bucks. Thanks for your help
fierosound
Total ratings: 286
Report this Post09-30-2024 11:46 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wrecking yard. GM used the same alternator on 100s of their vehicles.
